Pipo M9 Max RileyROM 2.0
Perfect!!!!! Thanks!!!!!!Randy
Thanks for your help testing it...great job.Randy
After 8 hours of usage, happy to report no issues at all except antutu crash, no big deal there as it's not a critical app
Pipo launcher works after reboot, no longer asking for activation code, pretty cool but tiles are not live so switch back to plain launcher.
Multiwindows work well after some getting used to, the feature I look forward to most as I can now edit a doc while having email open and use IM+ at the same time, still smooth with 3 apps running
Riley, may I ask what are the changes in the final version? If it is only the boot animation & wallpaper for multiuser, I can stick to test version as I don't share my tablet & deleting the animation file works fine for me...Last edited by fztt; 28 October 2013, 03:13.
Originally posted by rrileypm View PostI'm not sure I can do anything about the wallpaper for the 2nd user...Multi-User is a feature that Pipo doesn't support, that I've added. I'll see what I can do.
Originally posted by adm510 View PostHi Riley,
Do we have TUN.ko added to this ROM as per your previous ROM's?Randy
Aditional problems
Well, I just have two other things to report.
First, the bluetooth, I use it to pair a keyboard and it connects well but it has a problem, after some time of inactivity the conection betwen tablet and keyboard gets lost and I have to power off and power on my keyboard to work again.
The second thing is the normal problem with multiwindow option that still hasnt be fixed, when multiwindow option is disabled there is a problem switching between aps, it just doesnt work.
ROM is smooth, but due to the bluetooth problem, I may reconsider going back to my previous ROM, anyway I may try fixing this by myself porting some stuff, just like I did to fix the buttons layout.
Hello again. One member from another forum experienced troubles with touch screen after 2.0 flashing. He's geting these error messages in kernel log
ct36x_ts 2-0001: CT36X chip: Failed to get fwchksum
<3>[ 3.915167] ct36x_ts 2-0001: Failed to init ct36x chip
<4>[ 3.915189] ct36x_ts: probe of 2-0001 failed with error -11
Touch screen is mirrored. Left side if working like right, right has weird behavior. What can be the source of the trouble? Is there any way to reflash touch controller firmware? Thanks in advance
Multi User Issue?
Hello,
I don't know if it's only me who's having this issue. When I add the second user, I just get the message "com.android.provision.DefaultActivity" on a black screen. Virtually not usable second user profile. Anyone else face this issue? Is something else needed to be set up? I'm using the PIPO launcher, if that matters!
thanks,
c
thanks,
c
This ROM works in my tablet like a charm, but i have some problems:
-The same problem with bluetooth keyboards that jninanyac has.
-When i use multiwindows i can hide the icon on the right of the screen, but when i come back from resting mode the icon is visible again.
I don't have any problem with Antutu or switching between apps with the multiwindows feature on, so for me is a very stable ROM. Thanks for your work Riley.
Sorry if my english isn't perfect.
remove provision.apk
thanks,
c
There are currently 2848 users online. 0 members and 2848 guests.
