Where is the CWM It doesn't have CWM ?
Pipo M9 Max RileyROM 2.0
Originally posted by WimUitTwente View PostAfter the first reboot from flashing when you want to use multi users, you need to use a rooted explorer app to remove provision.apk from the system/app folder.
Strange... both my M9's bought at the same time, serial numbers practically in sequence, antutu crash in one but not the other.
Yup, the multiwindow icon keep reappearing even after it's turned off.
These are minor annoyances though, good to have real sdk2 features finally, now monitoring battery life, hopefully as good as 19b.
I'll continue to play around with it. For now, this ROM is pretty stable for most users. I'll have to look into why the background image isn't working. The other tablets I'm testing rotate different screens for each user.
RandyRandy
Originally posted by rrileypm View PostI'll continue to play around with it. For now, this ROM is pretty stable for most users. I'll have to look into why the background image isn't working. The other tablets I'm testing rotate different screens for each user.
Randy
Originally posted by astrolabos View PostHi I have a problem with the ROM_Flash_Tool_137.exe
I have windows 8.1 (I have previously installed 1.9a in windows 8 successfully) and whenever I try to run it, I am getting an error "Device can not do switch,because of no drive". Does anybody knows what to do?
[ATTACH=CONFIG]3703[/ATTACH][ATTACH=CONFIG]3704[/ATTACH]
I would suggest using an old system if you have one with win 7 on it. Till then its a waiting game to we get more updated drivers and support for 8.1
Originally posted by madweegie View PostWindows 8.1 has no support "yet" for the drivers required to install to flash.
There are currently 1509 users online. 0 members and 1509 guests.
