Pipo M9 Max RileyROM 2.0
Originally posted by P.A View PostHello again. One member from another forum experienced troubles with touch screen after 2.0 flashing. He's geting these error messages in kernel log
ct36x_ts 2-0001: CT36X chip: Failed to get fwchksum
<3>[ 3.915167] ct36x_ts 2-0001: Failed to init ct36x chip
<4>[ 3.915189] ct36x_ts: probe of 2-0001 failed with error -11
Touch screen is mirrored. Left side if working like right, right has weird behavior. What can be the source of the trouble? Is there any way to reflash touch controller firmware? Thanks in advance
Apologies if this has been explained somewhere already. I did look, honest!
I'm trying to go from this ROM (and the corresponding flashing tool) back to a stock rom using the RKBatchTool but it fails each time. Is there something I need to do before being able to use the original way of flashing again?
If you are going back to a Jellybean ROM do this:
Open the flash tool of this ROM and get your tablet into flash mode.
Erase idb from the flash tool.
With the tablet still in flash mode, run the flash tool from one of my Jellybean ROMs...check the loader on the top line and flash the whole ROM.
There is a thread in the main Pipo section that gives more detail.
If it doesn't flash...you've bricked your tablet.
There's another thread in the main Pipo section that explains how to unbrick.
Sorry, I'm mobile...so I can't post links.Randy
Originally posted by rrileypm View PostIf you are going back to a Jellybean ROM do this:
Sorry...trying to remember all of these versions off the top of my head is difficult. Especially when I'm at work, without a PC to look it up.
The main cause of rkbatchtool to error is your USB connection. It is important to use the cable that came with the tablet.Randy
There are currently 1875 users online. 0 members and 1875 guests.
