Pipo M9 Pro RileyROM 2.0
Originally posted by Kastrup View Post
Colin,
Yes, seen the different previous responses one may assume that each Pipo M9Pro has a unique soul ...
I am never unhappy as I take every step as a challenge and a learning...
After I put the tablet to sleep it resets automatically on irregular intervals. It may do so after an hour or after X hours. This issue I had also with 1.8 and both 1.9/T1 & /T2.
Not sure what you refer to with "Google stuff". After restoring all my stuff with TB I found out that the only App not working at all was GMail, which I quickly fixed by downloading it from the store.
/Kastrup
Originally posted by colinabroad View PostGood morning Kastrup! I guess we all have different performing tablets then??!! I am most confused, but happy that you are happy with yours. what's the Auto-reset from sleep? I did not have that problem?? rgds, Colin. Do you have the Google stuff loaded, or is that missing on yours? -
Google Stuff
/Kastrup. Lets see what others get as the World wakes up!!
Google stuff -repl
Kolin,
Now that you mentioned all that I went back to check it and found that 'play music" is missing ... (I never use it on the tablet so I did not check before). I did a TB restore of all missing Apps right after flashing so I can't really say anything about the other apps as they are all there and working...
/Kastrup
Originally posted by colinabroad View PostIt is all very strange that's for sure! By Google stuff I mean ALL the Google apps - I was missing Gmail YouTube, Maps, Navigation, search, play music, voice search (I know, Navi has been swallowed up into Maps, but we were getting Navigation as well from Pipo) Play store (yes, missing!) I did an all missing apps restore with TB first and it was AFTER this restore that the icons on my home screen did not work - I then went back and restored manually to get Gmail and the others Google play services was missing as well, so quite a lot of stuff - in fact all the stuff you get when you restore gapps with CWM on a phone (for instance) this is what seemed a bit odd to me - maybe my flash did not do everything, but I left it alone to do its stuff??. Lets see what others get as the World wakes up!!
Originally posted by colinabroad View PostGood - there are a few who don't!! Anyway, you can flash whilst charging - I do it all the time! no need to wait! By the way.....do you have a stock ROM downloaded as well just in case the flash does not work for any reason - you should be prepared for the worst and hopefully you will not need it!
Originally posted by Kastrup View Post...
However the 'auto-reset from sleep mode' is still alive and irritating more than ever...
/Kastrup
I'll play around with the "Keep Wi-Fi on during sleep" setting found in the advanced wifi settings to see if that has an effect.
Flashing V1.8
I have tried to flash V1.8 followed the tutorial and all went well. After the flash part the device stayed black,did not boot,so i followed the instructions in the tutorial at page 7 carefully,did not let go power button on IDB erasing and during FLASH ROM. The device still not boot up.
for Ludoke
Why play with 1.8 when a better 2.0 is available?
My suggestion:
1. download 2.0 (see #1 on this thread)
2. Connect your tablet to USB
3. click on 'Reboot to Flash mode' - see that RKAndroid is found at the bottom of the frame)
4. click on 'Erase NAND (IDB) - see that the process is competed successfuly...
5. clisk on 'Flash ROM - watch the process until it's successfully done - your Tablet will restart automatically and hopefully you will be happy again
Good luck!
/Kastrup
Originally posted by ludoke View PostI have tried to flash V1.8 followed the tutorial and all went well. After the flash part the device stayed black,did not boot,so i followed the instructions in the tutorial at page 7 carefully,did not let go power button on IDB erasing and during FLASH ROM. The device still not boot up.
Originally posted by Kastrup View PostWhy play with 1.8 when a better 2.0 is available?
My suggestion:
Good luck!
/Kastrup
Point 5 is the issue :device don't boot at all,screen stays black. Followed all the steps carefully.
Is V2.0 for 3G and how is GPS on this?
3G
Dear friends!
Please help me with included 3G.
All were good with my tab but 2 weeks ago 3G is dropped - Error while searching networks, in Status theres is:
mobile network type – unknown:0
Network – unknown
Sigal 2147473647 dBm 255 asu
Out of service
Mobile network – disconnected
MDN IMEI – unknown
I try to correct operator_table, spn.xml, but its not worked for me. I use 3 sim card - 3 operator and noone can find network.
I tried many ROMs - Riley Kasty Stock fo 06 09 to 30/10.
Please maybe you can help me to resolve this problem.
1.8 had some issues and therefore one get bug fixes and improvements.
2.0 works fine on mine (no 3G). GPS works fine too.
Don't be afraid to flash 2.0 - you have nothing to lose; only to gain.
/Kastrup
Originally posted by Kastrup View Post1.8 had some issues and therefore one get bug fixes and improvements.
/Kastrup
Flashing 2.0 tommorow and come back with the results,keep fingers crossed.
Edit: Flashing V2.0 succes, GPS still no good,no fixLast edited by ludoke; 02 November 2013, 12:39.
Originally posted by darrellr View PostStock kernel binary patched to 720 MHZ DDR @ 1.2V (stock 580 MHZ @ 1.3V) using script developed by PHJAnderson. Test at your own risk.
[ATTACH]3753[/ATTACH]
If you want to try 1.7 GHz or VSync patch let me know. So far these have not worked on any Pipo models
+600 points in antutu on riley 1.9test2 and riley 2.0 from stock to overclocked kernel, very well done
There are currently 1182 users online. 0 members and 1182 guests.
