Pipo M9 Pro RileyROM 2.0
does the choice of usb socket matter when flashing a rom?
Originally posted by Spinewinder View Post
removing sd
Originally posted by ludoke View PostAnywhone who knows how to remve the back cover ot the M9 Pro?
I have put a mini sim with a adaptor in the sim slot .
It's not recognized and can't remve it anymore .
It is spring loaded and will pop back out. Easy once you know the trick.
If you really need the back cover off search for the youtube video about it. There is a link onthe kirsty
Rom thread about getting a better gps signal. (I hope they were more careful with my unit!)
Thanks guy's
Originally posted by daviepl View PostI used my fingernails and starting at the bottom corner of the tablet I SLOWLY AND CAREFULLY pushed the plastic back from the screen, once you get the first corner off the rest is easy, loosen the bottom and both sides and it will slide away from the top edge, TAKE CARE the speakers and WiFi antenna are taped to the back panel.
While the alu back was removed i tried to see that GPS reception was improved(like some people mensioned) result is no better.
Originally posted by Stefan View PostThanks for the reply.
I did download it but Antutu still don't work?
What did you do to make it work? or maybe someone else?
Also someone who experience freezes and reboots with new 2.0??
Stefan
What I did, was to do each test one by one instead of doing all at once (I as trying to determine which part was crashing the tablet).
After running all of them successfully I was able to run the full test without any problem.
By the way, I got a score of 18804.
Originally posted by antoid View PostDebugging was off except for adb try.
With all your experience, does this sound like hardware now?
Thanks.Attached Files
Originally posted by colinabroad View PostDont just tell them what to do. Tell them HOW to to do it as well please! Thanks.
Regards
Originally posted by ludoke View PostWhile the alu back was removed i tried to see that GPS reception was improved(like some people mensioned) result is no better.
Go outside, find a clear sky
Hold tablet in portrait mode with camera on right so antenna is pointing up
Do the figure 8 electronic compass calibration (see youtube)
Intstall ntpsync app. Run detailed query and note offset in milliseconds. My pipo is gaining about 1-2 sec/day, bad cpu freq. calibration?
Run query and sync to reset the clock. If return ping time to server is long consider to add 2 letter country code before pool url. E.g. uk.pool.ntp.org
I don't think gps.conf suggestion is good for wifi only, or when cell coverage is bad (since no ntp available when you need gps most).
See /system/etc/gpsconfig.xml for TWO places with coldstart locations. Need to remount system dir as superuser r/w to edit it. Maybe better to leave this file alone.
Install gps test app. In settings select update AGPS. I think this is the almanac/ephemeris.
Also in settings set keep screen on.
Wait for fix, first time could take some minutes.
Once you have a fix keep it in the app with a fix for 30 minutes. Do not switch away from app.
Good luck, this worked for me.
Originally posted by mattiesrag View PostI'd really like to know how to "fool" the tablet into thinking it's a phone (step by step please). Surely1 if this can be done, then installing MESSENGER for smssing would be possible!
Originally posted by M9ProPipo View PostSome tips (mostly from the m9 kirsty rom gps thread)
Hold tablet in portrait mode with cameraon right so antenna is pointing up
Intstall ntpsync app. Runn detailed query and note offset in milliseconds. My pipo is gaining about 1-2 sec/day.
Run query and sync to reset the clock. If ping time to server is long consider to add 2 letter country code before pool url.
I don't think gps.conf suggestion is good for wifi only, or when cell coverage is bad (so no ntp available when you need gps most)
See /system/etc/gpscpnf.xml for TWO places with coldstart locations. Need to remount system dir as superuser to edit it. Maybe better to leave this file alone.
Install gps test app. In settings select update AGPS. I think this is the alamac/ephemeris.
After running GPS test for 1 hour i get now instant fix with Navigon ,Sygic, Copilot and Tomtom.
INDOORS by the way!!!
Kasty rom 20131010
fix usb drivers
Originally posted by picaye View Posti had some issues with my tablet not being recognized. reinstalled drivers with this here (attachment) which i found somewhere and then it found it again. hope this helpsThis little installer got my Win7 laptop talking to my PipoM9Pro in minutes with absolutely no problems at all. I had given up trying to get this computer working with the usual nightmare installation procedure, but this just installed and told me to connect. First time connection got me talking on both flash tools. Randy, I think you should seriously consider putting this in your ROM Installation pack - it will make that first time installation SO MUCH easier!
Originally posted by kumnamutata View PostI'm new here. First time I have installed RileyROM 2.0.
It seems everything working OK at the moment.
Antutu test score marked as 18731 on my Pipo M9 Pro.
How did you apply the kernel update?
By using the ROM_Flash_Tool_137 in the same way to install RileyROM?
What is your Antutu test score after overclocking?
Thanks in advance.
There are currently 2815 users online. 0 members and 2815 guests.
