Binary patched kernels for Pipo models
Originally posted by herrjemineh View Post
PiPo M6 Max 3G RileyROM 1.9
Hyundai T7s SPCleanROM 4.04
Asus Transformer Prime ChaOS 4.3.1
Samsung SGSII SlimBean 4.3 Build 2.2
1.5 modified kernels
Here are the most used modified kernels suitable for RileyRom 1.5:
kernel_1.5_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro.zip
kernel_1.5_cpu1704h_gpu600_ddr720_target_2.1.zip
kernel_1.5_cpu1704h_gpu600h_ddr720_VERY_LOW_voltages.zip
Enjoyif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostHere are the most used modified kernels suitable for RileyRom 1.5:
[ATTACH]4390[/ATTACH]
[ATTACH]4391[/ATTACH]
[ATTACH]4392[/ATTACH]
Enjoy
Can you describe advantages of each, please.
I want to know, because i never used patched kernels.
Thanks.
Thanks.
Low_voltages: Ram set to [email protected] CPU [email protected] Uses very low voltages (at least -100mV for every freq) wit respect to stock kernel, improved battery duration and better performance wrt stock. Stable on very few tablets (on mine is perfectly working).
target_2.1: RAM set to [email protected] CPU [email protected] Uses lower voltages wrt stock but slghtly higher than "low_voltages" one. Same performances of "low_voltages" kernel. Stable on most of M6pro.
1704@1325_Claro: set to [email protected] CPU [email protected]. Uses the SAME voltages for the CPU as stock kernels with a little increase to get it stable at 1704Mhz. Voltage is reduced only for RAM. I assume that battery duration is equal with the stock kernel. Performances are the same of the other 2 modified kernels. Stable virtually on any m6pro. I generated this kernel for very unlucky CPU.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Posteverything is written on previous page, I can summarized as follows:
Can you recommend any special software for stability test ?
Thanks.
Originally posted by claro966 View PostGreat!
Flashed the mod kernel Claro on RR 1.5 and sincerly runs smooth!
Thank you Giouncino
Let me use it for some time but really all seems ok!
Inviato dal mio ZP980 utilizzando Tapatalkif you appreciate my efforts this is the link for any donation:
overclocked kernels for RileyROM 1.6 - PIPO M6pro
here are the patched files for M6pro RileyRom 1.6 / 1.6.x
kernel_1.6_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro_test1.zip
kernel_1.6_cpu1704h_gpu600_ddr720_TARGET_v2.1.zip
kernel_1.6_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW.zipif you appreciate my efforts this is the link for any donation:
Re: Binary patched kernels for Pipo models
Originally posted by giouncino View Posthere are the patched files for M6pro RileyRom 1.6 / 1.6.x
[ATTACH]4576[/ATTACH]
[ATTACH]4577[/ATTACH]
[ATTACH]4578[/ATTACH]
Performance wise = superb.
3g connection = bad
Sent from my M6pro using Tapatalk
3g connection = bad
What you say is not completely true.
After a set of power off/on 3G works well as before...
I still don't know which is the cause of this strange behaviour. Because I changed voltages only for CPU and RAM...3G is driven by a completely different board soldered on the motherboard.
I tested also stock voltages with RAM without success.
I'm still working to understand what is wrong with 3G though.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI have 3G version. (kernel tested on 7 pipo m6pro 3G)
I intend a set of power off on of the COMPLETE tablet.
Try it for a couple of day if you have the opportunity, just to give me a more complete feedback.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI intend a set of power off on of the COMPLETE tablet.
Dilemma.
Stock kernel is good for 3g but performance wise ia a bit laggy.
Your kernel has that 3g problem but performance wise is superb!
Really hoping a very new discovery by you. :-p
Sent from my ZP990 using Tapatalk
There are currently 2841 users online. 1 members and 2840 guests.
