with 720 maximum that i got was 18900+.
Binary patched kernels for Pipo models
Originally posted by giouncino View PostThis is the HIGHEST result for an M6pro I have ever seen!
Very good result!
Thanks!
The only thing holding it back now seems to be the slow NAND. If not it wasn't for that I'll finally be able to stream 1080p MKVs from my NAS without buffering skips.
Can somebody remind me again....
How do you run a kernel through the perl script that only has one entry in the DDR table. I keep getting errors. I'm trying to patch a kernel for the Ugoos UT1.Randy
Because Stock kernel has only one entry for RAM but the script is for sticks and has 2 rows for different freq/volt.if you appreciate my efforts this is the link for any donation:
Hmmmmm, I'm not sure I understand exactly what to remove from the script.Randy
OK...I think I got it.
Thanks!!!!!!Randy
herrjemineh, just few messages ago on this page:
giouncino
RAM steps are at 24Mhz.
There isn't predefined values because on that table can be set only ONE value, BUT rising RAM frequency over 720Mhz seems to increase memory latency.
720Mhz seems to be the best trade off between RAM bandwidth and latency.
Originally posted by Reolin View PostCan anyone please tell me table right table numbers for M7 Pro? I always get the same error - CPU profile table is larger than the CPU table in the kernel, I checked the script - cpu table seems to be OK.
Run the initial part of the script and determine how many steps there are for the CPU Table of your kerenl. You will then have to edit the script to have the same (or less than) the steps of your kernel. This will correct the error.
Originally posted by TerryH View PostThe CPU table of your kernel has 'x' entries. The CPU parameter of the script you are attempting to update your kernel with, has greater than 'x' entries resulting in the error you receive.
Code:Rockchip Patchomatic Suite Overclockomatic v1.0 by phjanderson ============================= Reading kernel image Done! Searching volt/frequency tables Done! Volt/frequency tables found in the image: == Table 1 at offset 9396868 == MHz mV == Table 2 at offset 9400344 == MHz mV == Table 3 at offset 9400392 == MHz mV == Table 4 at offset 9400480 == MHz mV == Table 5 at offset 9400576 == MHz mV == Table 6 at offset 9409748 == MHz mV == Table 7 at offset 9409812 == MHz mV == Table 8 at offset 9409876 == MHz mV == End of tables == Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel.
There are currently 2128 users online. 1 members and 2127 guests.
