Binary patched kernels for Pipo models
Originally posted by spawnofdonny View Postlike this on the attachment
target_v2.1:
mV Mhz
[850, 312],
[875, 504],
[950, 816],
[1000, 1008],
[1075, 1200],
[1175, 1416],
[1275, 1704],
very_low:
mV Mhz
[800, 312],
[825, 504]
[900, 816],
[950, 1008],
[1050, 1200],
[1125, 1416],
[1275, 1704],
Claro:
mV Mhz
[900, 312],
[925, 504],
[1000, 816],
[1075, 1008],
[1150, 1200],
[1250, 1416],
[1325, 1704],if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postthey are currently lower than the one on your attachment:
target_v2.1:
mV Mhz
[850, 312],
[875, 504],
[950, 816],
[1000, 1008],
[1075, 1200],
[1175, 1416],
[1275, 1704],
very_low:
mV Mhz
[800, 312],
[825, 504]
[900, 816],
[950, 1008],
[1050, 1200],
[1125, 1416],
[1275, 1704],
Claro:
mV Mhz
[900, 312],
[925, 504],
[1000, 816],
[1075, 1008],
[1150, 1200],
[1250, 1416],
[1325, 1704],
No, you cannot change parameters on the fly.
Only supported kernels can do thatif you appreciate my efforts this is the link for any donation:
Is there anyway to get a vsync patched kernel for the M9 Max? I have a user in Spain who needs one for his tablet. He started this thread, if you can chime in....http://www.freaktab.com/showthread.php?9598-Some-issuesRandy
Originally posted by rrileypm View PostIs there anyway to get a vsync patched kernel for the M9 Max? I have a user in Spain who needs one for his tablet. He started this thread, if you can chime in....http://www.freaktab.com/showthread.php?9598-Some-issues
Originally posted by giouncino View PostHere are the usual patched kernels suitable for RileyROM 1.7 KitKat! for Pipo M6pro.
With all of these kernels and kitkat antutu can reach more than 20600 points!
[ATTACH]4643[/ATTACH]
[ATTACH]4644[/ATTACH]
[ATTACH]4645[/ATTACH]
Enjoy!
Originally posted by levicius View PostGiouncino, I tried all you kernels for 1.7 , but the Autuntu is crashing in 3D test , any ideas ? Also tried all the kernels you did for Kimmem .
here is my current cpu profile (works great on my current kernel):
Code:"cpu1704h" => [ [875000, 312000], [900000, 504000], [975000, 816000], [1025000, 1008000], [1100000, 1200000], [1175000, 1440000], [1300000, 1704000], ],
Originally posted by dmr View PostI got same error when I tried make patched kernels for myself. Don't know right i did or not, but +25 mV on last the cpu frequency helped me fix these errors.
Originally posted by dmr View Postummm, sad
Drm please ,could you edit this kernel for me please ? I am getting autuntu crash when running 3d test as I told you before .
Thank you.
Thank you.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postif it doesn't work with CPU set at 1.325V I suggest you to install the kernel with RAM overclocked only
First I place the image file in RileyROm folder and rename it to kernel.img and replace with the original
Second I click Reboot to Flash Mode
Third I Flash Rom with only Kernel box selected
What about these adress number 0x00...etc , do I have to change them too ?
Strange because all kernels I tried in 1.7 is crashing when 3d testing in antutu
Is there anyway to flash the kernel that I dont know ?
Everything you did is right.
It seems strange that the app crashes on 3D test...Because I didn't modify the GPU part of the kernel
you can try reinstalling Antutu.
Are you sure that with stock kernel everything works fine with antutu?if you appreciate my efforts this is the link for any donation:
thanks
There are currently 3223 users online. 1 members and 3222 guests.
