Binary patched kernels for Pipo models
only if you want better performance and/or less power consumption...if you appreciate my efforts this is the link for any donation:
You cannot use my modified kernel for your M8HD.
But you can use the same script I prepared and posted to modify your kernel and make it working.
Battery savings depends on how good is your CPU, if you are luky you can save up to 100-125mV for each frequency of CPU and up to 100mV for RAM, and increase performances based on antutu score by 10-15% max.if you appreciate my efforts this is the link for any donation:
read the previous pages: I have explained at least 2-3 times!!!if you appreciate my efforts this is the link for any donation:
I need some time to prepare all the modified kernels:
Tomorrow I'll post the usual 3 kernels.
Stay tuned!if you appreciate my efforts this is the link for any donation:
Pipo M6pro RileyROM 1.7 Kitkat KERNELS
Here are the usual patched kernels suitable for RileyROM 1.7 KitKat! for Pipo M6pro.
With all of these kernels and kitkat antutu can reach more than 20600 points!
kernel_kitkat_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro.zip
kernel_kitkat_cpu1704h_gpu600_ddr720_target_v2.1.zip
kernel_kitkat_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW.zip
Enjoy!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostHere are the usual patched kernels suitable for RileyROM 1.7 KitKat! for Pipo M6pro.
[ATTACH]4643[/ATTACH]
[ATTACH]4644[/ATTACH]
[ATTACH]4645[/ATTACH]
Enjoy!
Thx giouncino.
Althou I have the same problem as with JB.. it still freezes on 27% in antutu (even with claro).. but I have had it flashed with target 2.1 and everything worked fine in JB, all games run good, never any hangups or crashes, just with antutu. So I let it run with ur kernel.
So I use ur Claro and it works good. Big thx.
/Kimmen
probably you need a little bit more voltage for 1.7Ghz...
1.35mV could be enough.
I'll prepare it for you soon.if you appreciate my efforts this is the link for any donation:
It seems that you still have trouble on maximum frequency for the CPU.
Last possibility is to use 1.375V on CPU...
Try this one: kernel_kitkat_cpu1704h_1375mV_gpu600h STOCK_ddr720_Kimmen.zip , if this is still not working, I suggest you to use a modified kernel with RAM but with CPU on stock 1.6Ghz (I can prepare it for you, in case), just to be sure to have a perfectly stable Tablet.if you appreciate my efforts this is the link for any donation:
Originally posted by Kimmen View PostThx.. but unfortunately my tablet crashed on 21% in antutu (cpu float), as usual.. it works of course when I have default kernel in 1.6 ghz.
Thanks again for the kernel giouncino
Originally posted by spawnofdonny View Postwhich version of antutu are you running i tested kernel_kitkat_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro.zip and i got 20425 with antutu 4.1.5
I used the kernel "very_low" but it can be used only on very lucky CPU because voltages are reduced a lot.
To have a consistent result with antutu: remove any external micro SD, switch wifi off and wait a couple of minutes after boot to finish all the startup processes.
In any case a difference of 200-300 points and even more is normal. You can see that may vary for any run of Antutu!if you appreciate my efforts this is the link for any donation:
There are currently 2120 users online. 0 members and 2120 guests.
