To flash the mod kernel you need to EXTRACT the file inside the ZIP and flash the kernel with the flash tool (NOT TWRP!!!!!). You can flash the KERNEL ONLY (= no data loss)
Binary patched kernels for Pipo models
Originally posted by Divemaster View Post
To flash the mod kernel you need to EXTRACT the file inside the ZIP and flash the kernel with the flash tool (NOT TWRP!!!!!). You can flash the KERNEL ONLY (= no data loss)if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostNot necessary: you need only to flash the misc.img to go outside TWRP.
Originally posted by Divemaster View Postthanks for the answer, tablet runs, but not fine.... the PlayStore dosnt work properly, I can't download Aps, error 403 !?
It is not related to the kernel....
At the moment I can't help you more than this!if you appreciate my efforts this is the link for any donation:
was missed. Now Playstore workes fine.
And than I tried to flash the Kernel by your explaination... done, reboot, and now I see only the first grafik from rileyrom... 15min..... nothing more!?
Re: Binary patched kernels for Pipo models
Originally posted by Divemaster View Postthis issue is be solved. Settings/security/unknown sources
Sent from my ZP990 using Tapatalk
Originally posted by ninjakura View PostI have got the same issue. Can't even reset the tablet. Zzzzz
use the reset pin to switch off the tablet
connect the tablet via USB to the PC
open the flash tool
simultaneously press power AND volume+ for a while
wait until "RKloader found" on the flash tool on PC
try flashing another kernel (ONLY THE KERNEL and WITHOUT ERASING IDB)
You probably need a kernel with higher voltages like the stock (try to flash the "kimmen" version that is the one that will work for SURE)
NOTE: remember to extract the kernel before select kernel to be flashed!!!!if you appreciate my efforts this is the link for any donation:
open the flash tool
Have no idea what to do now.
Originally posted by ninjakura View PostHav tried. Not working at all. Now even the first riley rom graphic does not appear. When i connect to pc, flash tool just recognize my tablet only for 5 secs.
Don't worry, You've not bricked the tablet!!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Posttry to connect the tablet to the wall charger and follow the steps I've posted above.
Originally posted by ninjakura View PostIt's ok now. I removed sd card before pressing volume + and power button. I have no idea at all why it worked. LoL.
Sent from my ZP990 using Tapatalkif you appreciate my efforts this is the link for any donation:
Originally posted by r0llingmuffin View PostIs there a guide "how to flash custom kernel"? ..... do i have to backup my old kernel and how? ........ sorry, but i'm a noobie ...
it is not necessary to backup stock kernel (it is included in the rileyrom suite)if you appreciate my efforts this is the link for any donation:
Originally posted by Billcnz View PostYou don't really "need" to update the kernel but it can give you a bit more performance as well as save some battery due to the reduced voltage. Individual CPUs don't all have identical performance / stabillity which is why Giouncino gives us a few to try for each rom version. I haven't tried them all but usually use the one labelled "claro" which gives an extra 1000 points on Antutu or +5% with respect to stock.
Sent from my GT-I9100 using Tapatalk
Originally posted by todguy View PostI'm thinking of putting the kit kat 1.8 final on my unstable stock 4.2.2 M6 pro wfi, but after reading the threads I think I also need to update the kernel too. However, how do I tell quick one I need?
My M6 Pro Wifi was never 100% stable until I installed that, and I'm still using RR1.4!!!
If you do upgrade to RR1.8, giouncino has kindly done a version of the '825' kernel for that ROM.
There are currently 2629 users online. 1 members and 2628 guests.
