Binary patched kernels for Pipo models
    Originally posted by stevejc View Post
    Can we mode the GPU as Randy asks ?
    I don't know what values to set.
    The GPU mod in terms of Voltage / freq in the kernel is not a right way to proceed because:
    - the changes in voltages are totally ignored by the tablet (if you set on table 7 all frequency at 800mV everything will work perfectly)
    - the only increase in freq can be made changing the 600Mhz value to 768Mhz and at stock voltage it is really really difficult to have a stable GPU. For M6pro I decided to not touch the table 7 of the GPU. You can try, but you will easily see artifacts on 3D tests...
    The most important thing is that about the kitkat kernel for the M8HD we can now summarize these information (virtually applicable for all RK3188 tablets):
    1 - the RAM table is 8 ONLY (because, reading on the RK3188 specification, the RAM can have frequency of multiple of 24Hz only, for this reason stock table 9 seems not to be relevant to RAM settings because there aren't multiple of 24).
    2 - about the DDR part of the script (example):
    [1250000, 528256],
    the number
    528256 must be read "528" "256" where 528 = frequency in Mhz (MUST BE a multiple of 24 to be acceptable) and 256 = table parameter associated to "DDR_normal" operation (for m6pro the parameter is 001, and i think that 1 => "1 DDR_FREQ_SUSPEND" is WRONG, it should be as per parameter 256: 1 => "1 DDR_FREQ_NORMAL"). Both numbers are necessary in the script to be correctly used by the tablet.
      [1250000, 528256],
      the number
      Thanks for you explanations.
      As D33 said, table 9 is only used by RK3188-T (lower frequency), that are found in TV Stick.
      for us (tablet users) table 8 is the one.
        Hello, stevejc.
        Could you post your kernel version which has 20500 in antutu?
          Re: Binary patched kernels for Pipo models
          Using low v2
          Sent from my M6Pro using Tapatalk
            Originally posted by krolmo View Post
            Hello, stevejc.
            Yes, of couse, but you can try my script and adapt voltage
            My kernel :kernel_cpu1704h_gpu600_ddr667.img DDR voltage : 1250 mV (stock Volt)
            If you have a lucky cpu you can try :
            kernel_cpu1704h_gpu600_ddr720 : DDR voltage : 1300 mV
            or maybe
            kernel_cpu1704h_gpu600_ddr720stockvolt DDR voltage : 1250 mV (stock volt)
            and for very Lucky CPU
            kernel_cpu1704hmin_gpu600_ddr720stockvolt with minimum voltage for CPU
              As I read TV stick forum, I look at boot.img.
              In the file init.rk30board.rc, I noticed these following values have been set when loading GPU (mali driver) during boot
              insmod /system/lib/modules/mali.ko mali_dvfs=50,100,133,160,200,266,400 mali_init_clock=50
              I have changed to as D33 suggest.
              insmod /system/lib/modules/mali.ko mali_dvfs=133,200,266,300,400,600 mali_init_clock=133
              and even
              I didn't really see any change
              How can we monitor the frequency really used by GPU ?
                and even
                unfortunately there isn't anything to monitor the GPU frequency as far as I know.
                Pay attention that on RK3188 tablet the mali is already set at its performance limit... so there isn't much room for improvement...
                What I want to tell you is that Iexploring overclock of mali is a waste of time in terms of performance gain in my opinion, the only thing that could be useful is try lowering the voltage (if there was a way to do that!) to improve battery duration....
                  and even
                  cat /sys/dvfs/dvfs_tree
                  dmesg
                    dmesg
                    Unfortunately this command doesn't give you any info about the current frequency used by the gpu, but give you only a feedback of the freq/volt programmed in the kernel...
                      You can get current GPU freq with
                      cat /proc/freqs |grep gpu
                      (not quite sure about /proc/freqs don't have a device in hands)
                      Sorry,/proc/clocks instead of freqs
                      Отправлено с моего ZTE V975 через Tapatalk
                      https://www.paypal.com/en_US/i/btn/x-click-but11.gif
                        It shows the current rate as well:
                        <4>[74368.314833] | | |- clock: gpu current: rate 594000, volt = 1250000, enable_dvfs = ENABLE
                        <4>[74368.314905] | | |- clk limit:[133000000, 600000000]; last set rate = 594000000
                        Anyway, dnkn's suggestion gives a more readable output.
                          QUOTE=dnkn;161164]You can get current GPU freq with
                          Отправлено с моего ZTE V975 через Tapatalk[/QUOTE]
                          Using that command the results are:
                          Sh: gpu: not found
                          Sh: cat: <stdio> broken pipe
                          What am I doing wrong?
                            M6pro Kernels for KITKAT 1.8 generated from new sources
                            Here in the following are new kernels for PIPO M6pro and RileyROM 1.8 (or Kitkat stock ROM dated february 13rd or february 20) generated from new source files (many thanks to user maakie), that slightly improve GPS functionality.
                            The user maakie added also the Hotplug governor (that can be set with setcpu or other SW), this interesting governor dinamically uses the necessary cores of the CPU and can set them "offline" independently to save battery.
                            He also added a new beautiful splash screen.
                            This time I decided to prepare more kernels based on the assumption that not all tablet are stable with ram set to 720Mhz only.
                            Here are the files:
                            HOW TO INSTALL KERNEL:
                            1 - Extract the kernel...img you want to flash from the zip file
                            2 - connect the tablet (In OFF state, NOT STAND-BY) to the PC via USB cable
                            3 - Open riley Flash tool
                            4 - DESELECT all settings EXCEPT KERNEL.IMG
                            5 - Click on the column "..." of the flash tool at the height of the kernel.img, browse and select the correct kernel...img file extracted from the zip
                            6 - Press simultaneously power AND volume + of the tablet until the flash tool detects your tablet
                            7 - Press "Flash Rom" (DO NOT ERASE IDB)
                            The process is really fast, when it's complete the tablet automatically reboots. Now you can disconnect the tablet from USB and enjoy better performace and longer battery duration!
                            NOTE: if the kernel is not stable for your tablet you can try another one. Pay attention that the general rule for stability is:
                            ABOUT CPU:
                            CPU STOCK (STABLE FOR EVERY TABLET)
                            cpu1704h_1325mV (GENERALLY STABLE)
                            cpu1704h_target_2.1 (STABLE FOR SOME TABLETS)
                            cpu1704h_825_users (STABLE FOR SOME TABLETS)
                            cpu1704h_VERY_LOW (STABLE FOR FEW AND LUCKY OWNERS)
                            ABOUT RAM:
                            ddr648 (MOST STABLE)
                            ddr672 (GENERALLY STABLE)
                            ddr720 (GENERALLY STABLE)
                            ddr768 (STABLE FOR SOME TABLETS)
                            ABOUT Battery duration:
                            cpu1704h_825_users or cpu1704h_VERY_LOW and RAM ddr648, ddr672 or ddr720 will give you the best ombinations for battery saving.
                              whats the difference between these and old stock one.i couldnt get the old ones to work.should i just flash the new stock one over the old one.
                                Yes, you can try...
