Binary patched kernels for Pipo models
Nice work!
Added kernel_GPS_cpu1704h_1325mV_gpu600_ddr768.zip, 100% stable in antutu stable test and did 5-6 runs in antutu:
Fast and fluid!
Originally posted by Pipo2000 View PostOk, thanks.
I will pay attention to it and come back when I have a conclusion.
Where did you buy/order the spare charger ? (in case off....)
I need to check something more....if you appreciate my efforts this is the link for any donation:
Re: Binary patched kernels for Pipo models
Originally posted by giouncino View PostI'm now having the same issue of lack of charging when in off condition!
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
One more thing I notice with the new kernels is the quality of the audio is reduced so there's some distortion when playing sound files. I'm using tablet for language study so I need to hear the words clearly so I will revert to previous version but I was really impressed with GPS performance it picks up satellites much faster.
Originally posted by Billcnz View PostOne more thing I notice with the new kernels is the quality of the audio is reduced so there's some distortion when playing sound files. I'm using tablet for language study so I need to hear the words clearly so I will revert to previous version but I was really impressed with GPS performance it picks up satellites much faster.
About the battery indication, it could be due to a complete different kernel (with new sources used to generate it) it could be necessary to perform a battery calibration with the corresponding app ("battery calibration" app), after a complete charge at 100%.
Furthermore a collegue of mine told me that he charged the tablet from off condition without any ssue. I need to investigate a little bit more. In a couple of days I will be able to say if there is really something wrong with these new kernels or not.
I tested these kernels for a while before publish them here, but I didn't charge the tablet, I coudn't image that there was this kind of issue...
Stay tuned!if you appreciate my efforts this is the link for any donation:
Originally posted by karmantyu View PostHi Giouncino,
Is there a reason I cannot see the DDR table (8) when I run the script on your kernels?
see here : http://www.freaktab.com/showthread.p...l=1#post159218
Originally posted by stevejc View PostYes, the scripts must be adapted to KitKat kernels :
see here : http://www.freaktab.com/showthread.p...l=1#post159218if you appreciate my efforts this is the link for any donation:
Thank you everyone. My M6pro is running the Giouncino kernel kernel_GPS_cpu1704h_825_users_gpu600_ddr768 happily with modified GPU voltage table
[875000, 133000],
[900000, 200000],
[950000, 266000],
[975000, 300000],
[1025000, 400000],
[1175000, 600000],
I've noticed in SetCPU that for 1704MHz CPU frequency 1300mV is shown (In the script 1275mV is written). It is either SetCPU showing wrong information or 1275mV cannot be set for 1704MHz.
Batt indicator is doing weird stuff.
My batt indicator is at 48% for about 2hrs now while my wife is playing Candy Crush so it should descent in one way or the other.... I'm not shure at what level my batt really is now...
Recently I also have the 'volume' bug. For no reason, and while nobody touches the volume buttons, the volume bar appears for about 2-3 secs and then hides itself again. No harm done but I didnt have this with JB, it only started in KK and have the same issue with the new GPS kernel also.
As of KK 1.8 I also got now and then that the app that I'm using is minimizing (not closing or crash). It simply goes to background. When I recall the app, it continues where I left it.....not a deal breaker either but worth mentioning.
I have seen the volume slider popup issue with RR 1.8 also, not related to custom kernel just something causing a false trigger.
For the frozen battery % try plugging in charger and see if it starts climbing. If it does it will clear battery stats when it gets to 100% and it maybe OK on the next charge cycle , if not wait for new kernels from gouincino.
Originally posted by Billcnz View PostI have seen the volume slider popup issue with RR 1.8 also, not related to custom kernel just something causing a false trigger.
We will see...if you appreciate my efforts this is the link for any donation:
Originally posted by karmantyu View PostThank you everyone. My M6pro is running the Giouncino kernel kernel_GPS_cpu1704h_825_users_gpu600_ddr768 happily with modified GPU voltage table
[875000, 133000],
[900000, 200000],
[950000, 266000],
[975000, 300000],
[1025000, 400000],
[1175000, 600000],
you can set all voltages for GPU to 800mV without any issue, So the GPU voltage cannot be changed in kernel.
Already tested!if you appreciate my efforts this is the link for any donation:
I'm seeing the battery percent problem as well. Last night I plugged it in while it was still booted up, and it was charging fine. Then an hour later, I shut it down while it was still plugged up, noting that it was at 84%.
The next morning when I unplugged and booted up, I noticed that it still said 84%.
Even after flashing a new kernel, and running antutu performance and stability tests while unplugged it still said 84%. I then booted into recovery and the battery percentage there was 88%, which sounds reasonable.
Sent from my M6Pro using Tapatalk
There are currently 1997 users online. 1 members and 1996 guests.
