Binary patched kernels for Pipo models
Originally posted by MartyK View Postif you appreciate my efforts this is the link for any donation:
Notice GPS not being recognised
I've recently updated to one of the kernel_GPS_1.4 kernels (actually I've tried a few) and I've now noticed that my GPS on my M6Pro isn't being recognised.
I have a GPS app installed that used to work and show all of the satellites detected, etc. Now it shows nothing.
Have I missed a thread on this?
Originally posted by ksaro1 View PostI've recently updated to one of the kernel_GPS_1.4 kernels (actually I've tried a few) and I've now noticed that my GPS on my M6Pro isn't being recognised.
my tablet is working with GPS without any issue...if you appreciate my efforts this is the link for any donation:
I know this isn´t for kernal but my thread is dead.
Hi, Iknow this isnt suppose to be in this Thread but my thread is "dead" and i am need som help.I did this one Pipo M9 Pro RileyROM 2.7 KitKat and it went well, no problem. The pipo where not slow and lagging after, verry sharp when i jump between stuff. But when my girlfriend played a game, the pipo first froozed, then made a sound of click/snap/ from the inside. Then it went black, someone who can help. Or is it hardware issue, the pipo still got power. Because when i connect it to the computer the sound of a new device sounds, and when i push the startbutton the sound sounds again. Someone who can help please send me a PM
Originally posted by varmasfalt View PostHi, Iknow this isnt suppose to be in this Thread but my thread is "dead" and i am need som help.I did this one Pipo M9 Pro RileyROM 2.7 KitKat and it went well, no problem. The pipo where not slow and lagging after, verry sharp when i jump between stuff. But when my girlfriend played a game, the pipo first froozed, then made a sound of click/snap/ from the inside. Then it went black, someone who can help. Or is it hardware issue, the pipo still got power. Because when i connect it to the computer the sound of a new device sounds, and when i push the startbutton the sound sounds again. Someone who can help please send me a PM
I think it's an HW failureif you appreciate my efforts this is the link for any donation:
Originally posted by ksaro1 View PostIt seems you have to enable blue tooth. Why is that?
I enabled Bluetooth and GPS is working.
I've NEVER enabled bluetooth.
Bluetooth uses another antenna wrt GPS...and frequency are not so close (2.4Ghz fo BT, and 1.575Ghz for GPS).
Seems a non sense to me....if you appreciate my efforts this is the link for any donation:
Randy
I try the overclockomatic patch, but the max cpu frequency is correctly set to 1608 in the original kernel.
It can be a governor issue.
I've experienced the problem on freshly installed Linux Mint 17.
Code:============================= Rockchip Patchomatic Suite Overclockomatic RK3188 v1.2 by phjanderson ============================= Reading kernel image Done! Searching GPU frequency limit cap Found: 133000000, 600000000 Patching... Searching volt/frequency tables Done! Volt/frequency tables found in the image: == Table 1 at offset 10258224 == MHz mV == Table 2 at offset 10261756 == MHz mV == Table 3 at offset 10261804 == MHz mV == Table 4 at offset 10261892 == MHz mV == Table 5 at offset 10261988 == MHz mV == Table 6 at offset 10272956 == MHz mV == Table 7 at offset 10273020 == MHz mV == Table 8 at offset 10273076 == MHz mV == Table 9 at offset 10273100 == MHz mV == End of tables == Please identify the CPU, GPU and DDR table. Press ctrl-c to cancel. Which table is the CPU table? (The CPU table is mostly the largest table ranging from 312 to 1608 MHz
The issue does not depends on version of overclockomatic and/or kernel version.
Is new version of perl causing the problem? Can anyone solve it?
Originally posted by MartyK View PostIm right to do this just before flashing right?
Thanksif you appreciate my efforts this is the link for any donation:
Are these kernels (also quoted from Giouncino's message) compatible with RR 1.8.2? I have just flashed latest RR couple days ago, and it finally works perfect with 3G and GPS. Antutu is just 18700-18800, is new kernel worth trying? Earlier I suffered heavily from bad 3G, it was working only where excellent field, other places just E-network... I don't want to go back thereI did use stock libril.
Originally posted by fokemon View PostAre these kernels (also quoted from Giouncino's message) compatible with RR 1.8.2? I have just flashed latest RR couple days ago, and it finally works perfect with 3G and GPS. Antutu is just 18700-18800, is new kernel worth trying? Earlier I suffered heavily from bad 3G, it was working only where excellent field, other places just E-network... I don't want to go back thereI did use stock libril.
My kernel 1.4 works on 1.8.2if you appreciate my efforts this is the link for any donation:
There are currently 1928 users online. 0 members and 1928 guests.
