Binary patched kernels for Pipo models
Originally posted by lgalher View Postif you appreciate my efforts this is the link for any donation:
If probe recent kernel and I do not work. i put the file prior libril stock and nothing.
I tried to install these:
https://www.dropbox.com/s/hu6gauyot3...600_ddr672.zip (cpu1704h_VERY_LOW 672) EXTREMELY SLOW BUT IT WORKS
https://www.dropbox.com/s/a3369zlwvw...600_ddr744.zip (cpu1704h_VERY_LOW 744) INSTALLED BUT IS FROZEN IN THE HOME SCREEN. https://www.dropbox.com/s/8mh7cfnimr...600_ddr768.zip ((cpu1704h_VERY_LOW 768) INSTALLED BUT IS FROZEN IN THE HOME SCREEN.
I use my tablet specifically the kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2.zip because new me was impossible they can be used.
Originally posted by lgalher View PostIf probe recent kernel and I do not work. i put the file prior libril stock and nothing.
https://www.dropbox.com/s/xl3zmjvtaq...600_ddr648.zip
https://www.dropbox.com/s/0sfnnk8diy...600_ddr672.zip
https://www.dropbox.com/s/vs6sh8tak6...600_ddr744.zip
https://www.dropbox.com/s/pahtame7nm...600_ddr768.zip
just to see if is a problem of all new kernelsif you appreciate my efforts this is the link for any donation:
I installed the kernel you had told me and these are one on one results :
kernel_GPS_1.3_cpu_stock_gpu600_ddr768 icon and android is locked
Icon kernel_GPS_1.3_cpu_stock_gpu600_ddr744 bootanimation android and starts , starts making a noise and turns off.
Icon kernel_GPS_1.3_cpu_stock_gpu600_ddr672 bootanimation android and starts , and stays there .
Icon kernel_GPS_1.3_cpu_stock_gpu600_ddr648 bootanimation android and starts , and stays there .
These kernels without problems :
kernel_kitkat_1.8_cpu stock_gpu600h STOCK_ddr720_Kimmen.zip
kernel_kitkat_1.8_cpu_stock_with_reduced_voltages_ gpu600_ddr720.zip
kernel_kitkat_1.8_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro.zip
kernel_kitkat_1.8_cpu1704h_gpu600_ddr720.zip
kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_825_users.zip
Today I Wear kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2.zip.Va fine but I wanted to try these to see if they improve .
No longer whether it is normal or only happens to me .
thanks
Originally posted by lgalher View PostI installed the kernel you had told me and these are one on one results :
thanks
the most similar kernel wrt the one you are using is https://www.dropbox.com/s/a3369zlwvw...600_ddr744.zip
and I don't think there is something wrong that prevent the tablet's boot...
If you want, you can try reflashing the whole rom using this kernel from the whole flash process https://www.dropbox.com/s/a3369zlwvw...600_ddr744.zipif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI don't have any more ideas at the moment...
Giouncino Thanks for your interest, but no way, I've done what you've told me nothing.
However I flashed the rom but with the kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2.zip and perfect.
Originally posted by lgalher View PostGiouncino Thanks for your interest, but no way, I've done what you've told me nothing.
However I flashed the rom but with the kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2.zip and perfect.This doesnt make any sense....
At first i thought it was related to your ram speed, then again you have 2 failures with kernels where RAM speed is below 700Mhz and that should normaly always work, certainly when CPU is at stock speed.
I'm afraid you have a particular dificult tablet.
U8
No love for U8...Ultra U8 owner
Freaktab fan and PiPO Tablets PH member
https://www.facebook.com/groups/pipotabletsph/
Hi Giounino,
I, like to remod (with my best known cpu settings)on of your latestr 1.3 kernel please can you upload the script ( changed for KK kernel)again for KK kernel and m6pro3g
Because i change the ddr tablet to 744001 and run the script.
The Overclocomatick told no table 8 exist..Last edited by X-Ray; 09 May 2014, 13:20.
Originally posted by X-Ray View PostHamm ...
..8
Table does not exist.
Whats wrong?
Rayif you appreciate my efforts this is the link for any donation:
There are currently 3375 users online. 0 members and 3375 guests.
