Here in the following are new kernels for PIPO M6pro and RileyROM 1.8 (or Kitkat stock ROM dated february 13rd or february 20) generated from new source files (again many thanks to user maakie that prepared the original kernel from I generated these mods),
This new issue improves, as maakie says:
* Added color and sound control (use for example the app Trickster MOD to change settings)
* Added some schedulers and governors & fixed a bug in hotplug governor
* Deep sleep works with the stock libril-rk29-dataonly.so for possibly better 3G reception
Here are the files :
Here is the stock libril to be used with these kernels:
This libril file shall be copied into: /system/lib overwriting the previous file.
HOW TO INSTALL KERNEL:
1 - Extract the kernel...img you want to flash from the zip file
2 - connect the tablet (In OFF state, NOT STAND-BY) to the PC via USB cable
3 - Open riley Flash tool
4 - DESELECT all settings EXCEPT KERNEL.IMG
5 - Click on the column "..." of the flash tool at the height of the kernel.img, browse and select the correct kernel...img file extracted from the zip
6 - Press simultaneously power AND volume + of the tablet until the flash tool detects your tablet
7 - Press "Flash Rom" (DO NOT ERASE IDB)
The process is really fast, when it's complete the tablet automatically reboots. Now you can disconnect the tablet from USB and enjoy better performace and longer battery duration!
NOTE: if the kernel is not stable for your tablet you can try another one. Pay attention that the general rule for stability is:
ABOUT CPU:
CPU STOCK (STABLE FOR EVERY TABLET)
cpu1704h_1325mV (GENERALLY STABLE)
cpu1704h_target_2.1 (STABLE FOR SOME TABLETS)
cpu1704h_825_users (STABLE FOR SOME TABLETS)
cpu1704h_VERY_LOW (STABLE FOR FEW AND LUCKY OWNERS)
ABOUT RAM:
ddr648 (MOST STABLE)
ddr672 (GENERALLY STABLE)
ddr744 (GENERALLY STABLE)
ddr768 (STABLE FOR SOME TABLETS)
ABOUT Battery duration:
cpu1704h_825_users or cpu1704h_VERY_LOW and RAM ddr648, ddr672 or ddr744 will give you the best ombinations for battery saving.
Ram set to 744Mhz has the LOWEST voltage (1.2V). For me is totally stable.
Ram set to 648 and 672 are set to 1.3V (Stock, for best stability)
Ram set to 768 has the voltage set to 1.25V somewhere in the middle.
