Probably you installed something on the last rom that prevented 3G to working properly...
Binary patched kernels for Pipo models
only the lilbril affect 3G (and ram set to 720Mhz on old modded kernels), it's not a matter of other parameters in the kernel.
Probably you installed something on the last rom that prevented 3G to working properly...if you appreciate my efforts this is the link for any donation:
Most likely so. Anyway, I flashed new kernel, and test results are nice, antutu up to 20600. Also stability test was good, and 3G still working (2mbits, as earlier no connection).
I will continue using this, and report back after a while. Sad that I spent my vacation with s**ty connection...
Not sure whether its these kernels or not but i tried these series of kernels:
kernel_GPS_1.4_cpu1704h_1325mV_V1
I cant seem to get a strong GPS signal anywhere.
Using latest Riley ROM Kitkat.
Sygic Maps i have put on the device.
Says waiting for GPS signal for about 30 mins then picks it up for 2 mins then it loses it again.
Ive tried changing location settings to all 3 different ones... 3 different sim cards all 3g capable... Still no luck.
Maybe its sygic? But it seems to find it ok when programmed into the home wifi.
Not sure what to do really?
Thanks guys.
Originally posted by MartyK View PostNot sure whether its these kernels or not but i tried these series of kernels:
Thanks guys.
First of all the issues with GPS on m6pro is due to the WRONG antenna length (It's too short).
With my ex - m6pro I rebuilt the GPS antenna with the correct length (following the rule of antenna length = 1/2 of GPS wavelength) and I got a GPS working (non perfect but good enough to be used).
Then, another problem is due to a not good driver for the GPS on Kitkat. With JB the GPS worked better. If it's so important for you the GPS you can switch back to JB.
Generally speaking, GPS on tablet is not reliable at all because the antenna is built by only a simple dipole (very cheap and not suitable for navigation).if you appreciate my efforts this is the link for any donation:
my result + question
my result on AnTuTu its 26369
and my tablet its stabile!!!
Great job guys!!
Question:
can somebody help me with USB recording on my tablet
sofware support told me my kernel its missing somethin (dunno nothing about coding)
"missing option in the tablet's kernel: isochronous USB transfers"
TnX
Great job guys!!
Question:
TnX
Audio recording ?
I have added usb audio support on pipo tablet, maybe that can help you : here
There are currently 2856 users online. 2 members and 2854 guests.
