PS: I'm Italian too
Binary patched kernels for Pipo models
Originally posted by annaepi View Post
PS: I'm Italian tooif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostYou are right, with Jelly bean (i do not know if KitKat does the same) any kernel mod seems to affect 3G performance/stability for unknown reasons...at the moment
PS: I'm Italian too
Ps: Even you Italian? how beautiful
Originally posted by stevejc View PostI have posted the kernel of M8HD some posts above: http://www.freaktab.com/showthread.p...l=1#post156709
And the modified script that I'm trying to use here
Then I can test it, with my script I can't do anything about DDR.
But with CPU to 1704 and undervolted, I ve a good solution with KiKat, only 0.2% per hour in deep sleep.
Originally posted by stevejc View Postgiouncino have you tried to patch the kernel of M8HD ?
I will make some tests on M8HD kernels this evening.
Stay tuned!if you appreciate my efforts this is the link for any donation:
Originally posted by annaepi View PostHowever, wait for a version of Kit Kat that allows me to use sky go .. at this time I can not give up the 3G, because the 2G is slow ..
a presto,
ciao!if you appreciate my efforts this is the link for any donation:
FIRST ATTEMPT FOR M8HD - TOTALLY UNVERIFIED
You can try this one.
I cannot give you any warranty if it is working or not.
The main issue I can see is that after the modification the table 8 and 9 changed their default name as follow:
WAS: "256 DDR_FREQ_NORMAL" to: "1 DDR_FREQ_SUSPEND"
and WAS: "1 DDR_FREQ_SUSPEND" is: "2 DDR_FREQ_VIDEO"
this is due to how the system variables of the script are set, on following tests I will change the system variable tables too, but I prefer to have some feedback about this kernel mod, but the name of frequency could be not so important (i suppose...). I left untouched the relationship between the "normal freq" of table 8 and table 9 in terms of frequency difference:
was:
== Table 8 at offset 10224340 ==
MHz mV
528 1250 256 DDR_FREQ_NORMAL
== Table 9 at offset 10224356 ==
MHz mV
200 950 1 DDR_FREQ_SUSPEND
460 1150 256 DDR_FREQ_NORMAL
is:
MHz mV
720 1250 1 DDR_FREQ_SUSPEND
MHz mV
200 950 2 DDR_FREQ_VIDEO
652 1150 1 DDR_FREQ_SUSPEND
here is the file:
kernel_M8HD_cpustock_gpu600_ddr720_test_1.zipif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostThis is a first attempt to make a valid kernel for M8HD...
Same result as my test : poor fps in Antutu test.
Can't reach more than 14 fps, with kernel stock reach 20.5
Antutu score : 17700 / Riley 1.6 : 19500
So maybe the number is significant.
then I will modify the script as soon as I can to get the correct number!
thanks for the prompt testingif you appreciate my efforts this is the link for any donation:
Originally posted by stevejc View PostYou get it.
I have change DDR table
[1250000, 667001],
by
[1250000, 667256],
And now get 20500 !
Which is the name your script gave to that value?if you appreciate my efforts this is the link for any donation:
my %ddr_profiles = (
"ddrstock" =>
# [1100000, 400002],
[1250000, 528256],
"ddr667" =>
[1250000, 667256],
My tablet doesn't work stable at 720 with 4.2.2
Originally posted by stevejc View Poston the first DDR table number 8. just one value
"ddrstock" =>
[1250000, 528256],
"ddr667" =>
[1250000, 667256],
Ddr suspend
Ddr normal
Ddr video
Or what else?if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostReopen the mod kernel with the script to see how it is called the modified freq:
Ddr suspend
Ddr normal
Ddr video
Or what else?
MHz mV
720 1300 256 DDR_FREQ_NORMAL
MHz mV
In fact D33 give me his modifed script tat he makes for TV Stick
For TV stick, there are two values for DDR, I make a mistake when I change the values
This is the change he made (you notice 256 value)
# DDR profiles
# the final digit of the frequency signifies the following:
# 1 DDR_FREQ_SUSPEND
# 2 DDR_FREQ_VIDEO
# 4 DDR_FREQ_VIDEO_LOW
# 8 DDR_FREQ_DUALVIEW
# 16 DDR_FREQ_IDLE
# 256 DDR_FREQ_NORMAL
# only 1, 2 and 256 seem to be used in the source code for KitKat Android sticks and even though 2 is set it doesn't seem to be used. Worse - it causes instability in the CS919 TV Box so I removed it
my %ddr_freq_type_map = (
0 => "",
1 => "1 DDR_FREQ_SUSPEND",
2 => "2 DDR_FREQ_VIDEO",
4 => "4 DDR_FREQ_VIDEO_LOW",
8 => "8 DDR_FREQ_VIDEO_LOW",
16 => "16 DDR_FREQ_IDLE",
256 => "256 DDR_FREQ_NORMAL"
This is my working script : hereLast edited by stevejc; 21 March 2014, 22:09.
Originally posted by stevejc View PostWith a test at 720 I've got this with modified kernel
MHz mV
MHz mV
# DDR profiles
# 2 DDR_FREQ_VIDEO
# 16 DDR_FREQ_IDLE
0 => "",
For your information, on M6pro kitkat releases there is ONLY one table for RAM (and no traces of 256 DDR_FREQ_NORMAL or equivalent).Last edited by giouncino; 22 March 2014, 09:56.if you appreciate my efforts this is the link for any donation:
There are currently 1264 users online. 1 members and 1263 guests.
