now i get a 21.294 on Antutu .....
Binary patched kernels for Pipo models
Originally posted by Billcnz View PostYou don't need USB debugging checked. If your tablet is still booting ok run CPU spy app to check kernel
Sent from Tapatalk on my m6pro running Riley ROM 1.8 KK
with CPU spy you will see 1.7Ghz if you use a kernel with higher frequency.
Otherwise nothing is visible from CPU Spy.
Make a test with antutu: with ANY of my modified kernels will go over 20.000points.
The stock kernel is always below that.if you appreciate my efforts this is the link for any donation:
Originally posted by r0llingmuffin View Postkernel version in settings remains as 3.4.0 york@mid-Porsche Thu Feb 13 10:03:19 CST 2014.
Originally posted by claro966 View PostHi giouncino,
Back again after some time for job reasons.
Thank you for the customed kernels for RR1.8!!!!
I will install both tomorrow... :-)
Inviato dal mio M6pro utilizzando Tapatalk
Let me know if customized kernel for kitkat is good for you too!if you appreciate my efforts this is the link for any donation:
Damn... I installed KK at last, now that GPS works with it. After flashing new kernel, Navionics doesn't work anymore, but stops at the start. It worked ok with 1.8 package kernel. Could it be the kernel, or just app problem? Antutu with package kernel was 17000, with these in page 24 more than 20000. I would like to keep it that way...
Originally posted by fokemon View PostDamn... I installed KK at last, now that GPS works with it. After flashing new kernel, Navionics doesn't work anymore, but stops at the start. It worked ok with 1.8 package kernel. Could it be the kernel, or just app problem? Antutu with package kernel was 17000, with these in page 24 more than 20000. I would like to keep it that way...if you appreciate my efforts this is the link for any donation:
Originally posted by fokemon View PostDo you mean one in Randy's package, or factory stock?if you appreciate my efforts this is the link for any donation:
Gionuncino: Your kernel works like a charm!
I just want you to know that the kernel_kitkat_1.8_cpu1704h_gpu600h STOCK_ddr720_VERY_LOW_V2 seems to work very stable on my M6pro with Kitkat 1.8! I haven't had it for more then 4-5 hours so I can't say anything about the battery yet but it's stable and the Antutu value raised from 19566 to 20944.
Boot problem!
I flashed very low v2 kernel for RR 1.8 and now the tablet wont boot. I only see rileyrom logo for a few seconds and after that screen goes black. No luck either trying to get it back into flash mode. Tried removing sd-card and sim-card, nothing.
Any solutions? Before that RR 1.8 was running ok.
Janne
Originally posted by Janne View PostI flashed very low v2 kernel for RR 1.8 and now the tablet wont boot. I only see rileyrom logo for a few seconds and after that screen goes black. No luck either trying to get it back into flash mode. Tried removing sd-card and sim-card, nothing.
JanneI also popped in and out the sd- and sim-cards several times in the process...
Anyways I'm so reliefedbecause it's my wife's tablet and I already thought I bricked it...
Janne
There are currently 4170 users online. 0 members and 4170 guests.
