Enviado de meu SM-N9005 usando Tapatalk
Binary patched kernels for Pipo models
Everything ok now !
Originally posted by giouncino View PostEverything you did is right.
It seems strange that the app crashes on 3D test...Because I didn't modify the GPU part of the kernel
you can try reinstalling Antutu.
Are you sure that with stock kernel everything works fine with antutu?
Originally posted by dmr View Posti have a not big experience in overclocking, so i want ask: what are minimum/recommeded step for freq and voltage (now I make all tests with 12 for freq and 25 for voltage)
thanks
For frequency the step is 12Mhz (limitation by the local oscillator) BUT pay attention, because the frequecies that Android will use are written in a kernel compiled file called cpufreq.c .
In details are the following (they are written in many parts of this file):
{.frequency = 312 * 1000, .index = 10}
{.frequency = 504 * 1000, .index = 20},
{.frequency = 816 * 1000, .index = 30},
{.frequency = 1008 * 1000, .index = 40},
{.frequency = 1200 * 1000, .index = 50},
{.frequency = 1416 * 1000, .index = 60},
{.frequency = 1608 * 1000, .index = 70},
{.frequency = 1704 * 1000, .index = 80},
{.frequency = 1800 * 1000, .index = 90},
{.frequency = 1920 * 1000, .index = 100}
(don't care about the "index"),
Then if you set a freq of 1560 (130x12Mhz) this frequency is visible by Cpu Spy for example, BUT never used by android OS (it can be forced by CPU master only...).
So be careful "inventing" intermediate frequencies: they are totally useless!!!if you appreciate my efforts this is the link for any donation:
Originally posted by herrjemineh View PostAnd if we change the value in that file?
We have an already coded kernel in which we change some parameters without recoding again.if you appreciate my efforts this is the link for any donation:
Originally posted by fazerg View Postkernel sources are available for RK3188 but not for Pipo tablets. Therefore it's a really hard work to compile new kernel as you have to go through loads of things and select proper. Not even sure we can get all the drivers required to implement them.if you appreciate my efforts this is the link for any donation:
Originally posted by Billcnz View PostNice work giouncino, tested with Claro version, stable and antutu 21027[ATTACH]4789[/ATTACH]
Sent from my m6pro running Riley ROM 1.7 KitKat
Very good result!if you appreciate my efforts this is the link for any donation:
Re: Binary patched kernels for Pipo models
Enviado de meu Nexus 7 usando Tapatalk
RAM steps are at 24Mhz.
There isn't predefined values because on that table can be set only ONE value, BUT rising RAM frequency over 720Mhz seems to increase memory latency.
720Mhz seems to be the best trade off between RAM bandwidth and latency.if you appreciate my efforts this is the link for any donation:
tested: stock / 720 / 768 / 792
best results was on 768 (and i use it now and cpu table i posted before, antutu - 19400+)
1440Mhz for the CPU is not good for the reasons I told you before.
It is better that you set it back to 1416Mhz
For a JB rom 19400-19500 is easily reachable also with RAM to 720Mhz.if you appreciate my efforts this is the link for any donation:
There are currently 2344 users online. 1 members and 2343 guests.
