why the heck is this working for everyone but me??
Binary patched kernels for Pipo models
update:
now cpucpy shows deep sleep state as soon as pipo is not connected to pc anymore.
now it is charging, but i couldn't see less power consumption in sleep state
i'll check it until tomorrow
@kruzifix: use the tool ds battery saver, there you can set a delay for deep sleep after display-out
I've added the new file to my kitchen. The next RileyROM's will include the change.
Thanks!!!!!Randy
Originally posted by herrjemineh View Post@kruzifix: use the tool ds battery saver, there you can set a delay for deep sleep after display-out
PiPo M6 Max 3G RileyROM 1.9
Hyundai T7s SPCleanROM 4.04
Asus Transformer Prime ChaOS 4.3.1
Samsung SGSII SlimBean 4.3 Build 2.2
A Tale of Two Tablets
How could two M6 Pro tablets behave so differently???
Tablet #1 - Pipo M6 Pro, wifi, 16GB
Flashed with RileyRom 1.4
kernel_cpu1704h_gpu600_ddr720 - based on 1.4 - higher RAM 1225mV kernal works a treat!
Thank you to Randy, giouncino and heisenberg for turning a good tablet into a great tablet.
Tablet #2 - Pipo M6 Pro, wifi, 32GB
kernel_cpu1704h_gpu600_ddr720 - based on 1.4 - higher RAM 1225mV doesn't boot.
kernel_cpu1704h_gpu600_ddr720_target_V2.1 doesn't boot.
kernel_cpu1704h_1325mV_gpu600h STOCK_ddr720_Claro_test1 does boot but locks up at 21% during Antutu (Testing CPU Float performance)
kernel_cpu1704h_gpu600_ddr720does boot and again locks up at 21% in Antutu.
Stock kernel boots and appears stable but sometimes switches itself on when in standby. The same thing happened with Tablet #1 running kernel_cpu1704h_gpu600_ddr720 and was fixed by upping the RAM voltage.
So could this be the "unluckiest" M6 Pro tablet of them all??
Could one of you kernel wizards (I'm looking at you giouncino and heisenberg!!!) create a kernel for me that is based on Claro_test1 but with slightly higher voltages???
Originally posted by fazerg View PostReplace original ril-rk29-dataonly with one from attached archive and you'll have no problem with deep sleep without reboot or moving files.
I've not tried it yet but all who did confirmed working, just takes a bit longer to start 3G modem.
[ATTACH]4309[/ATTACH]
thanks
Originally posted by cxighma View PostHey how can I install that fix zip file ? I tried from recovery mode and that aborted.
thanks
There are currently 1982 users online. 0 members and 1982 guests.
