for all yr support++
HK1RBOX X4 1000M Firmware (Img and OTA)
Hi
Back to Stock dated 20211222 (device re-flashed well with AMLTool 3.2.0)
I'v installed my all required apk.s without any issue
Kodi 19.3 or 4 OK(installed 19.4)
Un-installed default KDMC(Kodi 18.9)
APKPure kinda un-stable! but under Freddy's advice,y can fix it+
One Apk.("TVPhoto" premium vers.) works again stable
BUT G.Play Store doesnt update! or if y updated thru Store or APKPure then its crashed or warned such as y get an warning;
...this version does not compatible with yr device,so go to Settings and than uninstall update... (but does not affected to me)
also "YouTube" as same G.P Store that what happened! if y updated than y wont sign-in!! so I'v uninstall this update and I'v signed in well
Note;this is VONTAR's Stock so,Launcher is different and fully custimize!(I like this)
and also I'v uninstalled some of Apk.s too
such as NetFlix,Amazon,Miracast,Disney,etc., (I use this apk.s partly fm my IPTV)
Originally posted by Alex87 View PostThank you for sharing this Rom with us. can I flash it into my HK1RBOX X4 100MB box? its a grey color edge not the Yello, I am not sure if it's ok to do that. Also to flash the OTA need an SDcard?
Not recommended
Files are For Yellow Cover
1000m Ethernet
** Maybe would work
Best Case everything works except Ethernet
Worse Case
No Ethernet
No Wifi
No remote control
No Front Display
Boot Loop
Bricked
Not recommended
Happy Testing
This one of the few "Chinese" boxes, that I actually like the firmware. I have been using it exclusively for a few days now (that is something new for me). Now that Gbox23 has provided the stock firmware in "img", it is most tempting to try firmware from other similar boxes, but I don't think any other firmware is as good as the stock one.
I have been using Kodi on this box and it is working amazingly..
Just my 2cents.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thanks for the link - used the OTA file to update the 202112 installed firmware by copying the OTA zip file to storage - NO need for SD or USB. Used the installed UPDATE app. Selected local file - file name eg the OTA zip - then hit update. Sat back waited for reboot to come up. Everything seem a little faster smoother if thats possible. All Apps I use seem to work fine. As I mainly use box only for IPTV apks I dont use KODI or Gallery so cant comment on them . It fits my needs so one happy bunnyLast edited by sesdave; 27 May 2022, 16:12.
No issues here as well with the OTA using Update App. I wished they updated Android Webview or Chrome and fixed the powering off issue. I hope a ROM comes available with Magisk, perhaps inspired by superceleron version for the Tanix X4.
Thanks!
Two side notes:
1- My friend's Tanix X4 on stock seems to power-off properly.
2- I'd an issue where the HK1 X4 was overheating, did a reset and concluded Button Mapper triggered the issue as soon as Accessiblity Services was enabled (two different versions, the newest and a very old one). Replaced the app with Key Mapper and no issues.
Hi
if you have some of issues with this ROM than prefere above (post.1 given by gbox23)
its more stable!
Kodi OK
Gallery;in every case had issue!
Apk.s also more stable
seems that HK1 is "over"! do not wait any ROM etc., (might be except custom ROMs as well)
probably in near future Vontar release/unveil a "NEW" box,as usually hahhaaa
and new toy coming from; ""X96 Max Plus Ultra"" 905X4
Originally posted by Alex87 View PostI don't understand if they have a new update ready so why do they don't push it via OTA?
The Update was probably one they were going to release months ago, but they moved on... I mean, not even a security patch nor Chrome was updated to a recent release. I wonder if they focused on Kernel only. Anyway, just opinions.
There are currently 2866 users online. 0 members and 2866 guests.
