HK1RBOX X4 1000M Firmware (Img and OTA)
Originally posted by bergamesk View Post
Hi Clark
sounds is good
have you tried/applied yet?
and you did it
need more info such as way of installation,etc.,
thanks++
Originally posted by bergamesk View PostHi Clarkss
...but the stock IR remote does NOT work...
just wondering and asking you;does any Air-mouse work??MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
bergamesk , can you test the CoreELEC OS on your HK1 box?? It installs perfectly on my box, but appears others are having difficulty..... Install it on a microSD card, it will not touch the Android on the box.
thanks
I tested CoreELEC on June 2nd using that same day nightly (I think later it was updated to June 3rd release), no issues but still doesn't shutdown properly, seconds later it restart just like on Android. Also, I can use 3840x2160 60fps on Android, but atm on CoreELC it doesn't seem to support it.
Thanks for testing CoreELEC and letting us know.
Originally posted by retroluv View PostI tested CoreELEC on June 2nd using that same day nightly (I think later it was updated to June 3rd release), no issues but still doesn't shutdown properly, seconds later it restart just like on Android. Also, I can use 3840x2160 60fps on Android, but atm on CoreELC it doesn't seem to support it.
Thanks for the update.
Also does your ethernet work? One of the tester says his ethernet port does not work.
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1732 users online. 0 members and 1732 guests.
