HK1RBOX X4 1000M Firmware (Img and OTA)
Originally posted by H-Tab View PostI'm using the latest SlimboxTV rom, based on the latest fw fom august. It is also compatible with HK1 ROBX X4. SimboxTV rom is very stable and you can choose between AOSP an ATV rom. AOSP is the best option in my opinion for our TV boxes.
It installed with almost no difficulty. I used a small stick (Q-tip) to hold down the button inside the 3.5mm audio jack, while I plugged in the male-to-male USB cable. Ran AMLogic Burning Tool version 3.20. The whole burn process was less than two and a half minutes.
I now seem to have full access to most of the Google Play store, instead of the limited selection available for AndroidTV. MX Player is streaming video flawlessly, which is exactly what I expected. Very happy with this rom, and I'd recommend it to anyone else who wants to try something on their HK1.
A quick tip: if you run into a problem logging into Google services after you burn the new rom, make sure you have Google Contacts set to "Also sync device contacts". You will have to use Contacts on some other device you already have set up.
All the Alphabet stuff is disabled as much as possible on my HK1 box - and still works fine for me
Originally posted by Jaidee View Post
Good info thanks but playing devils advocate I always thought AOSP was a great way to do away with Google services............
Originally posted by Ty_Bower View PostI've just received my HK1 RBOX X4 (1000M version with the copper colored top).
which is newer than others I've seen for this box.
Everything seems to function as it should. I'll be putting slimBOXtv on it soon.
I bought another one of these HK1 RBOX X4 units. It came with factory build RD2A.211001.002.eng.user.20231119.154820 release-keys
yes , that is the best Option for this Boxes ,
greetings / gefattern
There are currently 3006 users online. 0 members and 3006 guests.
