HK1RBOX X4 1000M Firmware (Img and OTA)
Originally posted by gbox23 View PostHi all,
I have added a new folder in the share link (imgswithvontarlauncher) with vontar launcher included in both img versions.
Hk1 launcher removed from both imgs.
I also tweaked vbmeta imgs. Kodi will now work without being booted out.
hope this helps
enjoy
hope this helps
enjoy
With Vontar launcher embedded as system/ui/launcher
If that is correct terminology
Ethernet
Wifi
Bluetooth
All working fine as well as all apps
I don't mess with launcher usually
After customing home screen
It looks like the Hk1x4 home screen
Ha ha ha
Thanks for your work!!!
Happy Testing
i have transpeed x4 1000M 4/128gb. just installed 2022.06.20 ota. zip. i don't know how to understand 1000Mbit or 100.no clue. asked transpeed, they didn't answer about that.
my remaining problems are:
1) reboot restart not working. goes shutdown (red led) completely. remote doesn't restart so i have to unplug /plug power cable. need restart fix.
2) ethernet has no software switch on/off in Android. need to unplug eth. cable to use wifi.
3) wifi works but very slow. it was ~5 mbps with 20220525 fw, now ~10mbps with 2022.06.20 fw. ethernet works properly 94mbps as expected. don't know how to know if it is 100 or 1000Mbit.
4) superuser root app very simple and not works as expected. adaway can't change edit hosts file. so i couldn't do any copy edit permissions changes files in root too. how to install supersu instead of stock root app superuser?
can i use hk1 custom fws or should i wait for transpeed cfw s. anyone tried hk1 cfws on transpeed?
also i never saw shedutil cpu governor and no sd cache io before. using 3c toolbox. usually devices kernels use interactive cpu gov and cq io. weird.
temp. around 67C btw. cpu governors can solve this high temperature if i had an option to change it. tvbox works usually 1000~2000 mhz, while my old devices work around 400~1000 mhz when idle or doing simple things like writing here.
Originally posted by riven4300 View Posti have transpeed x4 1000M 4/128gb. just installed 2022.06.20 ota. zip. i don't know how to understand 1000Mbit or 100.no clue. asked transpeed, they didn't answer about that.
This thread is about hk1 rbox so is difficult to answer questions about Transpeed x4
However / have test Vontar and Transpeed Firmware on my HK1 X4 and they are cross compatible with it.
These results are from Hk1x4 Firmware
1) Long press Powe button on remote control options to power off/restart
Both work no probs
Single press turns back on
2)Same need to unplug
3)Issues with boxes later released jl2101 ethernet transceiver
Mine has rtl 8211f
Need to take box apart to confirm chipset
4)The OS is a quazi hybrid they say/blend os android n atv
Root is not true root
Never has been
At least with Stock/Factory Firmware
You should have no problems Testing gbox23 Firmware on your Transpeed.
Should check wifi chip on your box
Is for 1000Mbit
Also there are custom Roms at 4pda
Happy Testing
Hi all
I have a HK1 RBOX S905X4 with Firmware ah212.HK1RBOX-X4_1000M_11.2022.03.05.13.49-ota
i can update through an OTA file, but I fail to update img file through a SD card or with Amlogic USB Burning Tool v3.2.0 through USB cable due to error code 10 in the usb driver despite my repeated attempts and on more than one computer
Please help me to solve this problemYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Uninstall UBT 3.20
Reinstall UBT 3.20
You will be prompted for drivers world cip
Say yes
Those are drivers you need
Finish instalation
USB male to male
Hold in reset button to connect to Tool
Originally posted by freddy View Post
Factory reset box (toothpick method)
Uninstall UBT 3.20
Reinstall UBT 3.20
Say yes
Finish instalation
USB male to male
I do that same problems not solved
Here is another method to try
Credit to mAtvXk
SlimBox Thread/discussion
XDA Forum
This is how I learned it
On PC have UBT 3.20 running
You have loaded image and Hit Start
DO NOT PLUG IN MALE TO MALE USB YET
On TV Box install
Terminal Emulator app/apk
Execute command
reboot update
As quick as possible +
Now plug in USB MALE toMALE
Should start burning process
Good Luck
Happy Testing
Originally posted by freddy View PostHere is another method to try
Credit to mAtvXk
XDA Forum
On TV Box install
Execute command
reboot update
Good Luck
Happy Testing
hope this helps
enjoy
Please have a look at the pre-installed Android WebView system
I'm having some problems with some apk files need webview
The app always failed to start
Hi everyone,
when I put the OTA on a USB-stick and install it in recovery, I get an error message that says 'package is for ah212 but excepted ah213' and installation is aborted.
Updater app recognizes the update but simply says 'ota package error' when I want to install.
Especially the first error I found interesting since I am very certain I have the correct box. (also, which product even is the ah213?)
I do not have a male-to-male cable but I don't remember ever needing one for an update on a box like this. Am I missing something?
Also, it is always best to install a new firmware using the Amlogic USB burning tool. You can make your own cable, by cutting an splicing two cables. Best to use "fat" USB cables.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 4458 users online. 0 members and 4458 guests.
