HK1RBOX X4 1000M Firmware (Img and OTA)
Originally posted by Danacy View Post
It it the latest one in the Google Drive from the beginning of this tread. I already re-downloaded it. The one before that, 03-05, also gives the same error. But I will try to get a male-male cable and try the Burning ToolMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thanks for the update Gbox23, used the OTA update, put it on a USB stick and used the updater App. All went perfectly and have an updated box. Everything seems to work fine so far. I was surprised that all my apps and settings were retained so the pain of re-installs was unnecessary. First impression was that video image seems a bit darker than the original ROM, is there any reason this should be?
There must be something in the firmware that you are trying to install. Try a different firmware.
Code:[URL]https://4pda.to/forum/index.php?showtopic=1037617&view=findpost&p=115047976[/URL] [url]https://disk.yandex.ru/d/3c75dB_qHh0qTQ[/url]
Originally posted by gbox23 View PostHi All,
Added twrp recovery in folder.
follow readme doc for instructions.
Can confirm works on Hk1x4 amlogic s905x4 4/32
Was testing slimbox vontar as android.
So went back to Factory Firmware from June this summer
Purposely turned off Root.
Following instructions from Readme
Boot to Recovery
Success!!!
Working TWRP
Happy Testing
Originally posted by Lyricman View PostThanks for the update Gbox23, used the OTA update, put it on a USB stick and used the updater App. All went perfectly and have an updated box. Everything seems to work fine so far. I was surprised that all my apps and settings were retained so the pain of re-installs was unnecessary. First impression was that video image seems a bit darker than the original ROM, is there any reason this should be?
I download OTA version, put it on usb, select the file in upadter, and i get online update:Error Ota Package zip file
There are currently 1133 users online. 0 members and 1133 guests.
