Perhaps you can post your thoughts on this device running COREELEC ON THEIR FORUM.
HK1RBOX X4 1000M Firmware (Img and OTA)
If the file is sc2_s905x4_1gbit.dtb (85.3 KB) posted 3 days ago around post #40, thats what I've. Otherwise it's something I don't see as a guest. The LED does indeed work tho.
Thanks!
Originally posted by retroluv View PostIf the file is sc2_s905x4_1gbit.dtb (85.3 KB) posted 3 days ago around post #40, thats what I've. Otherwise it's something I don't see as a guest. The LED does indeed work tho.
Thanks!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by emveepee View PostI am the one having Ethernet issues with my HK1 RBox. I turns out the 1000M Ethernet chip it uses, the JLSemi 2101, isn't supported by CoreElec. It does work a fine in Android, I was getting good number with iperf3
MartinMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostCoreELEC now works on this device!!!!!
Most Excellent !!!
Following thread on discourse
I liked your u tube video RE: rc maps config
Desktop shortcut nice
Iam doing something wrong however
Do you rename to .xml file ?
From text file ?
Something worked
Not remote from box
But Samsung TV remote works
Or does Coreelec have HDMI CEC settings always on ?
Like auto update!!!
Now a read there is Linux Desktop...
This little China Box just keeps chugging along
More Testing
Happy Testing
Originally posted by gbox23 View Post
You're very welcome!
I had to make my own img from the ota I received 17 times (lol) and Transpeed x4 img (It had the correct boot configuration for this box)
I'm never a fan of mix matching 2 different firmware's into one mash, but, it worked. Worked very good to be honest.
I do like the transpeed launcher a little better as it allows more of a customization. So I have changed that and removed some of the crappy apk's with my own.
(Don't harp on me, I know there is better launchers, But, I need to keep it as SIMPLE as I can for my clients lol which means less phone calls for me. I'm sure most on here understand what I mean)
I've always liked the HK1 line of amlogic. They always seem to have the "original's" for firmware's. Or at least, solid working ones (for my clientele needs).
This firmware was pretty much impossible to find anywhere in any forums, didn't realize it would be such a success on here.
Just glad I am able to share it, and hopefully some fantastic roms come from it (wink wink).
I've just received my HK1 RBOX X4 (1000M version with the copper colored top). I'm having difficulty getting the newer ROM flashed to it.
I tried the installed UPDATER app, but I see no way to select the OTA zip file. Do I need to save it to a particular location?
The included file manager app seems to be missing the edit functions. I can select one or more files, and I can access either the internal storage or a USB device. But there is no option to cut/copy/paste.
I tried placing the update image (.img file) on a MicroSD card using the Amlogic Burn Card Maker (v2.0.2) on my PC. Inserted the MicroSD card, held a toothpick on the button inside the AV port, then plugged in the power connector. It ends up in Android Recovery with the following: "WARNING: Previous installation has failed. Your device may fail to boot...". But it boots just fine, only there is no update installed.
Do I have to use the AML Tool (USB Burning Tool) and an OTG cable for this box? Do I need a particular version of Burn Card Maker, or USB Burning Tool?
Ty_Bower, I prefer using the USB Burning Tool. I am using burn tool version 3.2.0, and yes you need a PC running Windows and a USB male to male cord. You can make your own if you don't have one.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I succeeded in applying the OTA patch. I copied the OTA zip file to the MicroSD card. It did not install correctly from the Android Recovery console due to some error (ErrorCode::kInstallDeviceOpenError, E:Error in /sideload/package.zip). However, having the zip file on the MicroSD card, it was found by the UPDATER app. Installation from there proceeded without issue.
I haven't noticed any difference between the ROM that came shipped on the HK1 RBOX X4, and this presumably newer 20220305 update.
I am still somewhat confused as to why this box doesn't update from the MicroSD created with Burn Card Maker. I'm fairly certain I've successfully used this method in the past with other TV boxes.
Originally posted by Ty_Bower View PostI succeeded in applying the OTA patch. I copied the OTA zip file to the MicroSD card. It did not install correctly from the Android Recovery console due to some error (ErrorCode::kInstallDeviceOpenError, E:Error in /sideload/package.zip). However, having the zip file on the MicroSD card, it was found by the UPDATER app. Installation from there proceeded without issue.
I am still somewhat confused as to why this box doesn't update from the MicroSD created with Burn Card Maker. I'm fairly certain I've successfully used this method in the past with other TV boxes.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Also Gallery
Launch Kodi
Common with Factory Firmware first release
Hk1x4
Transpeed
Vontar
There have been new Firmware for
Transpeed
Vontar
Released maybe has resolved issues
Never any change logs released to explain????
Maybe latest Transpeed May 25th has fixed
Currently testing Vontar June release on Same Box as yours
*Sd card port seems to be working properly
Gallery good
Launch Kodi good
* Testing Coreelec would not load with new 2022 SD Card
Had to use older/ 3 or4 years SD Card to work.
Happy Testing
Originally posted by bergamesk View PostHi
I'v already sold out my HK1 device
th4 I'v bought fm Banggood a new box "X96 MAX+ Ultra" (picture performance a little bit better then HK1)
but remote such disaster,very bad sensitivity!
I use Air-mouse
You don't hang on to TV Boxes very long.
Shame you got rid of Tanix X4
Could be Testing Superceleron Latest for Tanix!!!
I have firmware for your box X96 MAX + Ultra
Maybe will flash to My HK1 x4
Check out Rom
If it boots???
Happy Testing
There are currently 1901 users online. 1 members and 1900 guests.
