Pipo M8 Pro RileyROM 2.1
Here is the reader app:
Randy
Re: Pipo M8 Pro RileyROM 2.1
@sebastian: Do you use this RileyROM or Xposed and GravityBox or something similar on your Pipo M8 Pro?
As far as I know that can't be combined, Xposed framework works only on AOSP or near-AOSP ROMs.
One more thing: can I use TWRP recovery instead or CWM?
Sent from my C2 using Tapatalk now Free
Originally posted by rileypm View Post
It goes in system/app with 644 permissions.Randy
You need an explorer app like X-plore. Change the configuration to root read/write (Superuser) mode and copy the app to system/app. Then set permissions for rwx on all lines (644).
RandyRandy
[QUOT=rrileypm;118434]You need an explorer app like X-plore. Change the configuration to root read/write (Superuser) mode and copy the app to system/app. Then set permissions for rwx on all lines (644).
Randy[/QUOTE]
When i use x-plore I am able to set the confgig fine and copy app to system/app the permissions is a bit more problematic there is three boxes for read write and execute. If I select them all the permissions are in the 700 odds the only however if I select all the read boxes plus 1 write I get 644 this does not enable for me though. Thanks for your time and patience
Originally posted by owim View Post@sebastian: Do you use this RileyROM or Xposed and GravityBox or something similar on your Pipo M8 Pro?
Xposed framework works with Android in general (GingerBread (limited functionality) to KitKat), but some modules works only with some types of ROMs, there are modules for Samsung TouchWiz that dont work with Xperia ROMs, and vice versa, or modules specified for AOSP ROMs.
About TWRP, I don't know any implementation of this recovery for our M8Pro, but I think that Randy is better suited to answer this question.
I tried it, but the touch screen doesn't work for the M8 Pro, or any of the other Pipo tablets...for some reason.Randy
Originally posted by rrileypm View PostYou need an explorer app like X-plore. Change the configuration to root read/write (Superuser) mode and copy the app to system/app. Then set permissions for rwx on all lines (644).
Randy
My ROM kit includes a template you can build a CWM flash ROM. Just follow the instructions in the txt file.
That of coarse requires that you already have CWM flashed to your tablet.Randy
Originally posted by rrileypm View PostMy ROM kit includes a template you can build a CWM flash ROM. Just follow the instructions in the txt file.
Sorry to be a pest I use that app for studying and it has been very good particularly for PDF it offers functionality that I have never found in any other app such as ezpdf etc
Originally posted by desmondo View PostRandy I don't have one but i have one of your older roms on file somewhere will that do the trick, can I not just flash that CWM ?
We never delete anything around here. All (most, anyway) previous ROM's are still available at their posted links. The newest one is best, though. Just download it and give it a try.
It is always best to flash for the first time using a PC. CWM can't format the partitions, and file sizes vary between ROM's.Randy
There are currently 2271 users online. 1 members and 2270 guests.
