i was meaning ´binaries appearing, hosted by and discussion forum in klingon like language ´
Pipo M7 Pro RileyROM 2.4
Re: Pipo M7 Pro RileyROM 2.4
Originally posted by fazerg View PostDoes anyone want to try a modified slightly overclocked KitKat kernel ?Randy
OK guys...
I'm headed out the door to a basketball game. I didn't have a chance to make a new thread, yet.
Here is the download link to v2.5. I will make a new thread when I get back.
DownloadRandy
I have been testing it for a little bit. It boots and everything seems to work. No crashes yet.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Thank you very much! will test now.Proud M7Pro owner and Freaktab fan
Mine is the same...the only thing I can oc is RAM.Randy
I have a new thread for v2.5 with KitKat:
This thread is now moved to the Pipo Archived ROM forum.Randy
Originally posted by steliosg13 View Post...
My google search is not working, i get the 'unexpectedly closed' error whenever i try to speak to google search!
Reflash the ROM
Search the forum (found the quoted post in this thread)
Clear Cache/Data for Google search
Wipe Dalvik Cache
Does Google search work for anyone with this ROM?
On a possibly related note (i.e. problem might be with google services) my Google Calendar does not Sync (i.e. calendar appears blank, even after refresh)
Things like google play store & music appear to work just fine.
_____________________
Just wanted to say thanks for all the work with this ROM, it seems far superior to the Stock rom in terms of performance.
If this problem is likely to be solved with future versions then no worries I'll be flashing the Kit Kat version when it comes out of BETA.
Edit : Calendar now works fine, looks like the problem was a temporary issue with Google services. Search, either by voice or text entry, works fine with other apps such as Chrome or Play store, it's just the search app used with Google now or the desktop widget that has the problem.Last edited by MR_Loon; 25 January 2014, 13:16.
Hey Riley,
I use your CustomRom for abouth a Month now and I'm really happy about it. But there are some suggestions, requests i would like to make.
1) My Mobile Data and WIFI are getting turned off, when my tablet goes to sleep mode. It automatically turns it back on when the tablet gets waked up, but this takes time and I always have to wait for it. Could you please make it possible for the User to deceide, whether or not the tablet will turn them off during sleep?
2) There is this button on the buttom-buttons row (back, Home, Taps, vol +/-) which will let these buttons row disappear, could you make it possible for the user to deceide, wether or not he wants this option? Because I want that row to stay there always but I accidently push it so often and this is annoying.
3) would be cool if you put that pipo family UI back into the rom as an alternative launcher.
p.s. Google search doesn't work on my tablet either, same error, the calender syncs fine though.
There are currently 2246 users online. 0 members and 2246 guests.
