Pipo M7 Pro RileyROM 2.4
Why can't you use the Reboot app? That's what it is there for. Can't you boot into the system?
Sent from my U8 using TapatalkRandy
Originally posted by ovecka View PostHow to get to CWM from outside the system? Vol+ Power doesn't work, obviously
Tablet off. Hold ESC + POWER together for 8-10 seconds, Pipo logo start but you hold both button and 3 seconds later you enter in the CWM recovery. It works like this for my Pipo M7 with RileyROM 2.3
Originally posted by herrjemineh View PostI noticed sth. really weird. My tab was asleep for about 3h. After it didn't wake up when i pressed power button. I could press it as long as i wanted. The only way to reactivate it was connecting it to usb..
Did anyone experience something like this?
Now, it works fine again
My google search is not working, i get the 'unexpectedly closed' error whenever i try to speak to google search! Anyone has this issue? Master Riley I cannot seem to uninstall and reinstall google search to see if the problem is fixed. There is no option to uninstall unlike my Samsung Galaxy S3 where you can uninstall and reinstall. Perhaps I will try and uninstall with Titanium Backup.
Originally posted by herrjemineh View PostThe Rom is fresh... just got back to 2.4 yesterday
How is GPS performance for you guys? I have used GPS Test app and GPS Tools app, cleared the GPS state and let them locate and lock to satellites in open space for about 15 minutes. It detects and locks to numerous satellites and does not loose signal. I've heard a lot of people have problems with their GPS but I think they are just doing something wrong. After the initial detection and locking by these apps I get a stable GPS fix after about a minute.
Hello guys, my tablet arrived three days ago, i'm very excited with it
It's the 3g version. I read all about Riley ROMs and decided to try it out. Installed v2.4, but the problem was it changed my IMEI to 12345678. I thought that wasn't normal, so I flashed 2.2, which works(IMEI was recovered, 3G working), but I get random reboots, which is very annoying.
Can you guide me as to how to backup and restore the efs folder so that I could flash 2.4(to hopefully get rid of these random reboots) and restore the IMEI to v2.4?
Is it possible to flash 2.4 without starting over? I really don't want to reinstall all the apps and download all the files.
Thank you!
Originally posted by rrileypm View PostWhy can't you use the Reboot app? That's what it is there for. Can't you boot into the system?
Originally posted by manao View PostTablet off. Hold ESC + POWER together for 8-10 seconds, Pipo logo start but you hold both button and 3 seconds later you enter in the CWM recovery. It works like this for my Pipo M7 with RileyROM 2.3
OK, sorry...I wasn't clear on the status of your tablet...Randy
No news yet...but I haven't had time today to look.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
There are currently 3025 users online. 0 members and 3025 guests.
