Skickat från min M7pro via Tapatalk 2
Pipo M7 Pro RileyROM 2.4
Originally posted by Dennta View PostI have used crossbreeder with all riley roms. Works well for me.
The apps listed on the article above though are more advanced and powerful. If one of them works on our Pipo it should make a massive difference, especially in OS - launcher lag.
Direct Injection Mod now discontinued due to 'kanging' or in other words other devs used his code to create similar stuff. However, the new project of this mod is now here: http://forum.xda-developers.com/show....php?t=2411161 and named Operation Killjoy.
Supercharger V6 is the most popular mod followed by Operation Killjoy and Pure Performances mod.
If somebody could try them out and check if they are working it would be great! Supercharger V6 is a little bit more complicated to install whereas Operation Killjoy is quite simple.
Originally posted by steliosg13 View Postgot my pipo yesterday and flashed rileyrom 2.4. Seems like a very snappy firmware. I will try and flash the Direct Injection Mod next.
I run an Antutu Benchmark with RileyRom 2.4 and got a result of 18990.
AFTER flashing Operation Killjoy Mod with CWM i run an Antutu Test and got 19770!!
All works fine so far and I still have not flashed a kernel with overclocked DDR.
Originally posted by herrjemineh View PostCan anyone please run the app speedtest.net? For me version 2.4 had issues with internet speed
I flashed 2.4 and I thought it helped, but no. Wifi download speed drops under 1 Mbps when I'm longer distance from the router, but sometimes it gets more than 15 Mbps. Still my other device works just fine at the same point.
I didn't notice this when I was using 1.7 rom, but now it has been annoying. Based on inSSIDer there shouldn't be any other wifi signals around which could cause issues too.
So, could wifi power be weaker on this rom? I have disabled wifi optimizing from the wifi settings too.
You may have a bad solder connection on your antenna inside the tablet. A percentage of devices have that problem.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by herrjemineh View PostThere you go...
i made some different kernels with different voltages...
like always, not every kernel is working on every device, have fun testing..
at least the 1704 stock kernel and the 1608 low voltage +25mv should work for everyone, i guess...
[ATTACH]4506[/ATTACH]
[ATTACH]4512[/ATTACH]
[ATTACH]4511[/ATTACH]
[ATTACH]4510[/ATTACH]
[ATTACH]4509[/ATTACH]
[ATTACH]4508[/ATTACH]
[ATTACH]4507[/ATTACH]
Sv: Pipo M7 Pro RileyROM 2.4
Originally posted by steliosg13 View PostI have flashed the 1608 DDR720 low voltage +25mv and works great! thank you very much! I am now running RileyRom 2.4 with your kernel and my antutu score went from 19700 to 20700 barely from the DDR overclock! I have uninstalled the Operation Killjoy mod as I had a slight problem with youtube buffering but i will try and reflash see if it makes a difference to my tablet! I have run several benchmarks with and without the Operation Killjoy mod and the score seems to be the same.My previous post stating that the mod gave me higher antutu scores is now false as i have triple checked it! Has anyone tried to overclock the CPU with apps like SetCpu etc? Does it work? I do not want to flash a kernel with overclocked CPU yet as it seems that they are not stable!
There are currently 2981 users online. 8 members and 2973 guests.
