Pipo M7 Pro RileyROM 2.4
Custom Kernels for RileyRom 2.4
There you go...
i made some different kernels with different voltages...
like always, not every kernel is working on every device, have fun testing..
at least the 1704 stock kernel and the 1608 low voltage +25mv should work for everyone, i guess...
kernel_cpu1704h_1300mV_gpu600h STOCK_ddr720_.zip
kernel_cpu1608h_gpu600h_ddr720_low_voltages.zip
kernel_cpu1704h_gpu600h_ddr720_low_voltages.zip
kernel_cpu1608h_gpu600h_ddr720_low_voltages (+25mV).zip
kernel_cpu1704h_gpu600h_ddr720_low_voltages (+25mV).zip
kernel_cpu1800h_gpu600h_ddr720_low_voltages (+25mV).zip
kernel_cpu1704h_gpu600h_ddr792_low_voltages (+25mV).zip
Here you go: (This is a temporary link...every once in a while, I do a little house cleaning).
Randy
only 1608cpu works on my tab. which performs better the one with +25mv or just the low voltage?
TIA.Proud M7Pro owner and Freaktab fan
[ATTACH]4506[/ATTACH]
[ATTACH]4512[/ATTACH]
[ATTACH]4511[/ATTACH]
[ATTACH]4510[/ATTACH]
[ATTACH]4509[/ATTACH]
[ATTACH]4508[/ATTACH]
[ATTACH]4507[/ATTACH]
Have you done any testing with regards battery life with the 1608 low voltage?
thanks for your kernels by the way!
Originally posted by herrjemineh View PostStock ddr rate is 580mhz.. the battery Life is a bit better, but not like twice as long sure... the biggest Problem with battery Life is the huge drain in sleepmode...
what does the +25mv mean as opposed to low voltage kernels? is it only used when the CPU is overclocked? an overclocked CPU logically means more battery consumption unless you are lucky enough to overclock with lower voltages?
I hope i receive a 'pure cpu' so i can overclock.
i dunno if you will have that problem or not...
look, i have a battery drain in deep sleep mode of about 1% per hour, which i find riddiculous...
my also china-device (mtk6589 smart-phone) has almost no battery drain in deep sleep... maybe 2% overnight..
but i have this drain as well when i put it into flightmode, even when i deactivate everything related to 3g, e.g. deleting all the 3g apps, lib-files, editing the build.prop etc...
some people say, that they have a drain of 2% overnight with this device, but couldn't experience that unfortunately...
regarding cpu voltages:
the "+25mv" is related to the low voltage kernel, so it's like following:
the low voltage kernel is with dram frequency 720mhz and 1200mv (stock: 580mhz @ 1300mv)
+25mv = 1225mhz
cpu frequencies are generally 75 to 100 mv lower than stock depending on the clock-step.
at 1608mhz stock voltage is 1300mv, low voltage kernel is 1200mv, +25mv means 1225mv
the other one is 1704@1300mv and 720mhz dram @1300mv
thats the reason why i thought, this one has to work for every device..
some say, that the 3g voltage is related to one of those voltages, so if your are experiencing lower 3g connection ability, tell me, i could make a kernel with stock voltages, 1608mhz and 720mhz ram
Originally posted by herrjemineh View Posti dunno if you will have that problem or not...
+25mv = 1225mhz
some say, that the 3g voltage is related to one of those voltages, so if your are experiencing lower 3g connection ability, tell me, i could make a kernel with stock voltages, 1608mhz and 720mhz ramLow voltage kernel should give a battery boost of at least 5-10% then! it's good! i didnt order the 3G M7 so thank god i will not have the battery drain issue.
Do apps like ''Set CPU'' etc. work in overclocking or undervolting the tablet?
Also, please guys and master Riley have a look at this 'PurePerformances Golden Edition'' mod on XDA:
★ [MOD] ◢ PurePerformances™X ◣ | Golden Edition | Scary performances on Android everything you've always wanted from a performance engine, but you never dared to ask...
I read very good comments about this performance mod. Give it a try people. It incorporates features of Crossbreeder and others mods but this seems more powerful. The same developer also created ''Pure Audio Engine'' which greatly improves the sound quality coming out of the speakers. http://forum.xda-developers.com/show....php?t=2293589
How do you guys find the GPS of the tablet?
Originally posted by herrjemineh View Postlook, i have a battery drain in deep sleep mode of about 1% per hour, which i find riddiculous...
Originally posted by herrjemineh View PostHow is your battery drain in ds? How do you check it? Dont install this mod, after flashin pure performance mode, my system didn't boot anymore and neefed to be reflashed, randy had the same... some tweaks of this mod are not good for pipo ;-)
I see..thanks for letting me know! there are 5 performance mods made by acknowledged devs listed here including the Pure Performances Mod: http://www.epiblog.in/2013/08/best-a...eaks-2013.html
The direct injection mod seems good and the supercharger v6. I don't have my pipo yet to test them but surely one of these mods should work with our tablet!
There are currently 2154 users online. 1 members and 2153 guests.
