Pipo M6 Max RileyROM 2.0
    New Version
    Please upgrade to kitkattttt
    This ROM will not work on an M6 Pro tablet!!!!
    This is only for the original M6 Max
    This ROM is based on a Pipo OTA update firmware dated 12/27/13.
    This ROM is:
    Rooted
    Completely Debloated
    Google Play Store fixes added, as well as the most up to date app
    Auto Install feature added on first boot (see this thread): Autoinstall You can install apk's automatically
    Working CWM Recovery will automatically be installed after the first boot
    English default, but with full language support
    Busybox commands added for init.d support
    Ext4 File system
    2, 4, 6, 8 or 12gb user app space (the default parameter is 4gb)
    Multi-user support
    KO files added for VPN support
    Boot animation by Tattan65
    Flash Tool by Finless
    Reboot app by Petrus
    Updated First Time User's Guide
    Also in the kit:
    RKBatchtool as an alternate way to "switch" to flash mode
    CWM Template to build a zip file to flash this ROM via CWM
    Rockchip Driver installer app
    Download
    Enjoy!!!! and Happy New Year!!!!!!!!
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com
    Donate!!! This fund helps me buy new tablets for testing. I don't currently have an M6 Max to test on.
      Are you running Dalvik or ART? There are problems with ART in these KK ROM's.
      Otherwise, I think this current ROM seems to be the most stable at the moment.
      Yes, we are working on firmware updates for these RK3188 Pipo's...but it will take some time. I hope you will be patient. Right now we only have sources for the M8HD.
      KK ROM? My M6 Max is 4.2.2. Or did I misinterpret you?
      PiPo M6 Max 3G RileyROM 1.9
      Hyundai T7s SPCleanROM 4.04
      Asus Transformer Prime ChaOS 4.3.1
      Samsung SGSII SlimBean 4.3 Build 2.2
        Upgrade
        Sorry I meant version 4.4.4
          Sorry, I get mixed up between ROMs sometimes.
          Randy
            Originally posted by Balrog View Post
            Thanks for the new ROM and a happy new year!
            Here are the V4- and V4.1-overclocked-kernels for Pipo M6 Max RileyROM 2.0:
            Kernel V4 (cwm- and img-version):
            [ATTACH]4552[/ATTACH]
            [ATTACH]4553[/ATTACH]
            Kernel V4.1 (cwm- and img-version):
            [ATTACH]4554[/ATTACH]
            [ATTACH]4555[/ATTACH]
            Have fun!
            Hi, I've installed the V4 CWM ROM, and my tablet now fails to come back from hibernation. I need to reset it, every time the screens goes off.
            Do you have a less overlocked (or even declocked) ROM to install?
            Thanks.
              Just use the stock kernel in the ROM kit from post #1
              Randy
                HDMI
                does hdmi work?
                i havent tried it yet, i dont have the cable. but if it does work i will buy one. thanks
                  Sorry, I don't have M6 to try HDMI.
                  Anybody else have an answer for him?
                  Randy
                    Working properly.
                    Thank you very much.
                    I dont have the cable hdmi too, but here he dont see hdmi image on tv. It is an italian forum.
                      kitkat rom
                      hdmi work on lg tv 32inch so good
                      any chance with kitkat rom for this dead jeallybean tablet?????
                        Can this rom will work on pipo m6 Max?
                        Sorry for my bad English.
                          Not that I know of...unless the Wayteq tablet is identical to the M6.
                          I wouldn't risk it.
                          Sent from my M8HD using Tapatalk
                          Randy
                            AW: Pipo M6 Max RileyROM 2.0
                            Out of curiosity I flashed the Wayteq FW yesterday. Touchscreen, Wifi and Battery Stats is not working. Back to old Jellybean...
                              Maybe with some flashable drivers and usb mouse.
                              Randy it's possible (you know the way) to put the drivers from our tablet to another better rom?
                                We are working on a plan for the M6. Slowry has agreed to make an attempt at a KK kernel from the sources we have. Be patient...this may take a while.
                                Randy
