Pipo M6 Max RileyROM 2.0
    Generally, the Pro version was a whole new build. Different wifi, different touch screen, other different parts.
    Randy
      Then it sounds quite a problem hahaha. Merge both doesn't look easy at all.
        Especially since I don't have the older version to test on.
        Randy
          It was quite long time ago, but in the M6 Max I didn't see too many external libraries/modules, everything looked as they were integrated in the Kernel Build.
          I don't now how good Kitkat build for M6 Pro will work using a M6 Max kernel build + some libraries.
          I could give it a try, but I am afraid I will see fire! :P. I am sure the PIPO guys have estrange dependencies :P
            Originally posted by willthrom View Post
            How different is the PRO from the MAX?
            I thought was only the GPS with same SOC.
            What could happen trying to flash the PRO Kitkat M6 in the M6 Max? Has anyone tried?
            Thanks.
            I tried it by accident. The WiFi doesn't work. Not sure what else doesn't work.
            That being said, I'm would be happy to be the guinea pig. I was able to re-flash back to Jellybean with no problems.
              hahaha, well you could try do it again + flashsing the 4.0 kernel from this thread for the M6 Max.
              Testing a little to see how many thing doesn't work.
              rilley can confirm if the Wifi module is build-in the kernel or a module. (I don't have the PIPO M6 now, so I cannot check it).
                I don't think he has the M6 model either. I could check it when I get home.
                  The problem is that you can't run a kitkat ROM with a jellybean kernel. Until someone builds a kitkat kernel, unfortunately....kitkat is a no go.
                  Randy
                    Well...shucks.
                    So...how do I build a kitkat kernel?
                      That's something I haven't gotten into.
                      Randy
                        Sorry for my bad English, but if you make ROM 4.4 for pipo m6 max, I can test it. Sorry once again.
                          4.4.2 kernel
                          Well...shucks.
                          I found this link that points to the 4.4.2 kernel sources of some other rk3188 devices. Could this be a starting point for building one for the Max-M6?
                            Originally posted by bstoop View Post
                            I had all this issues as well.
                            Returned back to: Pipo_M6_wifi_RileyROM_1.3.
                            The best rom in my opinion.
                            Thanks for this. I installed frontier rom and things are much better now. I thought my tab was broken, while it was this ROM all along.
                              1.3?
                              hi,
                              I just re flashed riley rom 1.3, cos i was nearly binned the tablet, it was so slow and laggy wit v1.9 and 2.0 even with over clocked kernel... was totally useless after 15-20 mins....
                              is frontier much better, quicker?
                                Originally posted by richiesuk View Post
                                hi,
                                It still lags a lot, but at least wakes up every time I press the power button. With 2.0 rom it was hanging during sleep daily, so I had to perform a reset through that tiny hole in the back and then to boot the tab... It was a nightmare.
                                I also tried installing CrossBreeder, but it's still very slow while browsing.
