Sent from my SAMSUNG-SGH-I537 using Tapatalk
Pipo M6 Max RileyROM 2.0
Yes this for both versions.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
No sound
Originally posted by struppi View PostHello
I have installed and now no sound.
Everything else works.
Did you ever find a fix for this? I've got the same problem. Everything is smooth as can be, but no sound at all.
Update: headphones work, but speakers seem to have gone dead.Last edited by jadecell; 10 February 2014, 01:25.
Reactivation of HD vs SD display mode
To re-activate the switch between HD and SD mode, you need to modify the system/build.prop as following:
change the /system/build.prop line ro.rk.resolution_enable to true (ro.rk.resolution_enable = true) from false which is the default and then restart. After restarting, the option will appear in the display settings, so you can select the SD (normal) analysis as before. (from Slatedroid forum).
This is well described here: http://www.slatedroid.com/topic/1004...tiers-rom-v13/
Originally posted by milander View PostTo re-activate the switch between HD and SD mode, you need to modify the system/build.prop as following:
And also for example wildblood from market is saying incompatible with M6. Can we fix this? Can we display it as a Samsung tablet?Last edited by EyezBerg; 27 February 2014, 14:19.
I just installed this V2 to my tablet, but I have major problem with touches in "home screen".
For example, if I want to move a certain app/icon, the pointer flickers all over the screen, which makes moving really impossible. (I can see it with the "show touches" enabled)
I installed it with the overclock mod.
Did you try it with the stock kernel first? Its kinda hard to troubleshoot with custom kernels unless you establish a baseline.
Originally posted by zdr View PostAfter each few days, my tab does not wake up any more and I have to do a reset to restore it. It's already annoying that it freezes, but on top of that I always have to search for some tiny tool to press freakin reset button. Any solution for either of the problems?
There are currently 1609 users online. 0 members and 1609 guests.
