UPDATED - NEW - Jynxbox M6, Mygica TV420, Geniatech TV500 - Finless ROM 1.4
great work on this Rom 1.4
Great Work
I installed the Rom and i love the speed
one small question is there anyway to support the mouse mode of the remote so we do not have to plug in a mouse ?
The new remotes that come with the M6 has that functionality but is no longer available after the 1.4 rom install.
I will look into it though as I did not test the remote with it. It might be a simple KL file set.
+1 for mouse mode remote
Great rom! Could you please figure out a way to get mouse mode working again on remote? Now on clicking it pops up the screen in right bottom corner with wifi info etc. Thx
go Finless go!
Originally posted by Finless View PostI did not change anything there from the stock M6 ROM from 0908.
720p/1080p
I changed from stock rom to finless rom and the to the pure linux build for the m6 and then back to finless. Just to see and compare. I mainly use it for xbmc and 2 advantages the linux build has it's supporting airplay, both audio and video and you are able to set xbmc to 1080p in settings. About the airplay it is a nice feature, but I guess future xbmc versions (Gotham will support it) so no problem. But the ability to set xbmc to 1080p is not available in stock or finless rom. I was wondering why that is and if there is a way to achieve it? Is it rom related, because I read somewhere if the system default output is 720p then xbmc will also be only set to 720p and no option to change that. Also will this affectv 1080p video playback within xbmc because it is upscaled? Thanx.
Originally posted by Lestercity View PostGreat rom! Could you please figure out a way to get mouse mode working again on remote? Now on clicking it pops up the screen in right bottom corner with wifi info etc. Thx
go Finless go!
It's the android kernel. The kernel is a 720P kernel. But there is a 1080P kernel available from Geniatech. If you use that kernel you should get true 1080P. The pure Linux kernel is a 1080P kernel.
1080p
Thanx for that info. Will search for that kernel then. Could you advice me on how to switch kernel on the m6. I switched kernel before on mk908ii with your rom and your tool. But think this is handled in different way. Will I have to put device in recovery mode like I did when I flashed your rom on it? Sorry for noob question.
Originally posted by Finless View PostIt's the android kernel. The kernel is a 720P kernel. But there is a 1080P kernel available from Geniatech. If you use that kernel you should get true 1080P. The pure Linux kernel is a 1080P kernel.
Hi Bob, you have any time soon to fix the mouse function on m6 remote. Reallt love your rom but missing mouse functionality and now using wired mouse is not so comfortable. Thx.
go Finless BOB
Originally posted by Lestercity View PostThanx for that info. Will search for that kernel then. Could you advice me on how to switch kernel on the m6. I switched kernel before on mk908ii with your rom and your tool. But think this is handled in different way. Will I have to put device in recovery mode like I did when I flashed your rom on it? Sorry for noob question.
Ok, it seems I found the answer myself here:
"Hello. I can confirm that all firmwares for the atv520 from Mygica and from Geniatech's website work interchangeably on my atv520. The ATV1200 firmwares also work on the 520. I have also just installed the latest firmware for the *atv520E* from Geniatech's website on my atv520, and it also works flawlessly."
Also my ROMs do not flash bootloader so you should never hard brick and should always be able to recover without making a special SDcard and shorting pins.
So just try the ROM and see! Just make sure you have a ROM to go back to.
Mouse Function Remote Control
Hi Bob, any progress on fixing mouse function remote control jynxbox m6 on Finless Rom? Maybe something I can do myself to fix this? Thanks on keep up the good work, Cheers!
Originally posted by Finless View PostAlso my ROMs do not flash bootloader so you should never hard brick and should always be able to recover without making a special SDcard and shorting pins.
Sorry been super busy with other stuff.
Remind me what ROM the remote worked in? All we should need is some .kl and other files from that ROM and it should work.
There are currently 2894 users online. 5 members and 2889 guests.
