UPDATED - NEW - Jynxbox M6, Mygica TV420, Geniatech TV500 - Finless ROM 1.4
Originally posted by Lestercity View PostSorry to bother you when you're busy. It worked with the standard rom that came with the box. Thx finless
OK never mind. I assume you have the Jynxbox M6 and on that latest firmware the mouse worked. I built this one from the Mygica ROM and thus it is missing the needed files the M6 ROM had.
I will see if I can fix that today and release 1.4A
Ok thats great!!! If you are interested here is the latest factory firmware rom for jynxbox m6:
Originally posted by Finless View PostOK never mind. I assume you have the Jynxbox M6 and on that latest firmware the mouse worked. I built this one from the Mygica ROM and thus it is missing the needed files the M6 ROM had.
Yes thanks. I have that ROM. I will get the files from it and since I do have the remote I will test it.
Ok that's fantastic! Really love your rom on jynxbox m6, they work great together and xbmc runs very well too. But sometimes missing the mousepointer while using apps. One little question since xbmc is almost on release candidate gotham and latest nightlys are running great also, using a mk908ii for that. Will for example the minix neo x7 be better on gotham compared to jynxbox? What is your opinion?
Originally posted by Finless View PostYes thanks. I have that ROM. I will get the files from it and since I do have the remote I will test it.
Honestly you never know really unless you try it.
FIXED!
OK Jynxbox remote mouse mode is now fixed.
It was a simple remote.conf file in /system/etc.
I am uploading the new 1.4a ROM now.
UPDATE New version 1.4a
UPDATE - Feb 21 2104.
My ROM is now updated to version 1.4a. This fixes the Jynxbox remote mouse mode button issue.
I updated the link in the first post but here it is below as well.
ROM -> Jynxbox M6, Mygica TV420, Geniatech TV500 - Finless 1.4a ROM (283 megs)
Enjoy,
Home button on tronsmart tms-01
Hi, i just flashed this rom on my ATV1200, it all looks to be working well apart from the home button on the Tronsmart tms-01 remote. I had this remote working fine on the Prometheus. I think I'm lacking a .kl file in the key layout folder but not sure which one.
Any ideas?
p.s.another great rom Finless
Cheers
Look at the remote.conf in /etc
Compare what I have with your Prometheus ROM. Probably only one button mapping difference.
tronsmart tms-01
I switched them over but no joy, I think remote.conf is for infra red remotes only, the tms-01 is a wireless usb dongle one. Someone on another forum edited a .kl file for the mele f10 pro, I was hoping to do the same or extract the one from prometheus rom.
Any ideas which one it is, or could I copy them all?
Cheers
Update, I renamed the keylayout folder to keylayoutold and pasted the Prometheus one in to system/usr/
Airmouse works fine now and home button, infra red home button doesn't but I dont use it anyway.
Thank you so much for fixing mouse function, gonna try the updated rom tomorrow and will get back with feedback! Thx Finless.
Enjoy,
Its Compatible :-)
Originally posted by tcpdwpzn View PostHi all. My first post here and first Android media player.
Would this ROM work for the MyGica ATV 520E? If so great, though any other ROM's recommended for this model?
Thanks...
Stock standard ROM, I'd like to know. Has anyone tried an Android 4.2 or 4.3 ROM on this spec device?
Thank you So much Finless
There are currently 2509 users online. 4 members and 2505 guests.
