Can you point to a thread that describes how to do this? I hate feeling incompetent or even impotent with things like this. Would be happy to do some reading and sort it out myself too! There are some basics that I'm missing and need to understand. Such as what's the difference between SPI and STVMX? Amongst others.
UPDATED - NEW - Jynxbox M6, Mygica TV420, Geniatech TV500 - Finless ROM 1.4
Originally posted by superfreak79 View PostMy issue (as described by Biatsch) is occuring with ATV520E. I have not flashed Jnyxbox Linux to my ATV1200.
Hey Bob, thanks for your efforts on this board.
inside Spi u find recovery, uboot and partitiontable (hope is true what iam writing) is base System for mtd layout and recovery
STVMX
Rom for STVMX Named-Box (has to be compatible to mtd layout)
so if u Flash stock Firmware for example , flash first spi then Rom
....my box now in example has jynxm6 Name and so i cant Flash original spi and Rom because its checked within zip files
I will make both a SPI for the 520 and 1200 removing the assertion check. Maybe later today.
Originally posted by Finless View PostI will make both a SPI for the 520 and 1200 removing the assertion check. Maybe later today.
STVMX
Originally posted by Finless View PostThis is the SPI for the 1200 correct? I have the 520 but it looks different so I have to make both.
To be clear, this enables flash back to Geniatech SPI from Jynxbox M6?
It's ATV1200 and ATV520 afaik
So you flash this first then flash the Android ROM of your choice.
hope u can fix this.......
Originally posted by Biatsch View PostIt Fails https://www.dropbox.com/s/bbt4gw4m6k...IMAG0262.jpg?m=
Here is the install script in SPI update.
show_progress(0.100000, 2);
show_progress(0.50000, 40);
assert(package_extract_file("recovery.img", "/tmp/recovery.img"),
format("MTD", "recovery"),
write_raw_image("/tmp/recovery.img", "recovery"),
delete("/tmp/recovery.img"));
show_progress(0.300000, 30);
assert(package_extract_file("uboot_MX.img", "/tmp/uboot_MX.img"),
format("MTD", "uboot"),
write_raw_image("/tmp/uboot_MX.img", "uboot"),
delete("/tmp/uboot_MX.img"),
package_extract_file("env_MX.img", "/tmp/env_MX.img"),
format("MTD", "ubootenv"),
write_raw_image("/tmp/env_MX.img", "ubootenv"),
delete("/tmp/env_MX.img"));
show_progress(0.10000, 0);
As you can see, it is failing when trying to format uBoot!
I can try to remove the format command and see if it will even write the raw image but I bet that will fail too.
There are currently 2032 users online. 4 members and 2028 guests.
