UPDATED - NEW - Jynxbox M6, Mygica TV420, Geniatech TV500 - Finless ROM 1.4
Originally posted by Finless View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Finless View PostYou might also check the MyGica web site as the rebrand many of the Geniatech boxes.
If you do find the stock firmware let me know and I can probably make you a custom ROM for it.
thanks
ronMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Finless View PostI cannot tell just by looking at it. It doesn't have a SPI update so it should not brick you hard. If it doesn't boot you should still be able to go back into recovery and flash another ROM.
BobMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostOk, thanks, that is reassuring. I will install it later today.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Usually you put the zip as downloaded on SDcard. You do not unzip it.
If when you unzipped it you had folders like METADATA, logo.img, etc etc etc... then the entire zip IS the update! Don't unzip it.
Originally posted by Finless View PostUsually you put the zip as downloaded on SDcard. You do not unzip it.
jynxbox_m6_finless14a.zip
finless_14a.img
boot_recovery.img
README FIRST.TXT
the only thing that works for me is your finless_14a.img file,
does any of this make any sense to you??
thanks, again
Originally posted by clarkss12 View PostI tried with the zip file, no go. Then I took the boot recovery file from YOUR rom and put it on the sd card with the zip file, still no go. Then I tried YOUR zip file and boot img file, still no go. In your file you have
finless_14a.img
boot_recovery.img
README FIRST.TXT
thanks, again
Originally posted by clarkss12 View PostOne thing I haven't done is do a system wipe before trying to install this rom, not sure if that makes a difference. One thing is for certain, when I installed your rom yesterday, it went flawlessly. I used your image file.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostGRRRRRRRRRRR checked the formatting of my 2gig sd card that I have been using, it was set to NTFS. Reformatted it back to fat32, added the zip file and your boot file, now it is installing. I have not idea how it got formatted to ntfs????????????? sooooooooooo basic. Now I will find out if I get my tv tuner driver back.
thanks, again
Originally posted by clarkss12 View PostI am very confused now. No matter what rom I try to install, even with different boot loaders, my box reverts right back to your rom. The recovery goes through all the install, but still comes back to your rom. Is there anyway you can make a rom that will replace your existing one on my box, using the rom that has the tv tuner driver, which I posted on dropbox??
thanks, again
Originally posted by clarkss12 View PostFinal update. Finally got the firmware with the tv tuner driver installed, whew!!!! I am still not able to get the tuner to pick up my ATSC signals, which was one of my concerns, but I will keep trying.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostEmailed Mygica last week about getting the correct firmware for my ATV1220 with the ATSC tuner driver. This morning I received a reply with link for the correct firmware. I installed firmware and device is back to original. I am soooooo impressed with the support from these Chinese companys. I had ordered from Aliexpress and Geniatech store front.
Thanks,
Originally posted by Finless View PostCan you share the link and I will download it and when I get time make a custom ROM for it.
Thanks,
Thanks, for your great support, Bob.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by khalberrou View PostI've got this messages
Assert failed: getprop("ro.Product.Decive") == "stvmx" || getprop("ro.Product.Decive") == "stvmx"
Installation aborted
Assert failed: !Less_than_int(1364272097, getprop("ro.build.date.utc"))
I always forgot to say thanks, thanks
use my bootcard to revert back to geniatech Android from jynxrom pure Linux
Recovery don´t work after reverting from jynxrom use files within update_spi_mx_20130805 AFTER REVERT FROM JYNXBOX.zip and Flash spi manually and all is done box will work originally uploading true 1080p Android Rom from geniatech https://www.dropbox.com/sh/1r3anv4hfubi5wr/Ss2bD31f9Q
made it by my own cause no other method was workingLast edited by Biatsch; 03-18-2014, 18:53.
There are currently 2030 users online. 4 members and 2026 guests.
