Ugoos UT1 - wasser firmware - KiKat Android 4.4.2
    version 1.0.1
    - perfect 1080p fullhd video streaming
    - multiuser support
    - usb webcam support
    - autohide status bar
    - multi usb partitions support
    - busybox up to date
    - google apps up to date
    - hardware keyboard support
    - lock screen support
    - google searchbar is disable by default
    - screen rotation support
    - enable tun in the kernel
    - notifacation sound support
    - reboot/sleep/bootloader mode dialog
    - init.d support
    - ir-remote, A2 Airmouse support
    - cwm recovery support
    - ntfs, nfs, cifs filesystem support
    - rooted
    Link download: wasser-firmware-ut1-1.0.1.zip
    please use RKBatchTool to flash the new firmware
    version 0.92
    - Ugoos Ut1, k-r42, t-r42 and MinixX7 (all revision support, please select the correct kernel)
    - Kikat 4.4.2
    - wifi support
    - ethernet support
    - init.d support
    - rooted
    - ntfs, nfs, iso, cifs filesystem support
    - preinstall es file manager, reboot
    - cwm recovery
    - 1080p24hz, 1080p30hz, 1366x768p60hz support
    - fix remote issue
    Link download:
    Be aware: it is your own risk!
    hi wasser, thanks! is this the 'follow-up' to your wasser-1.2.4 rom or a different one? will try it right away when i get home.
      HI Wasser ,
      i posted my Problems in KR42 Froum :-)
      svemo
        tried the firmware, first impressions (maybe the flash went wrong, ill try again in a bit):
        - remote app not working (keeps searching for device. i am on ethernet only)
        - the statusbar is on top? (doesnt seem to be the default kitkat statusbar either)
        - no sound output selection possible, hence no sound when i played a movie
        for the flashing procedure i used the RKAndroidTool provided in the zip, erased IDB, and selected the included files for loader, parameter, misc, kernel (ut1), boot, recovery and system, leaving adress default and backup unchecked. ill try again in a bit.
          0.92 is based on kikat-4.4.2 which still has some problems. For example. TVOUT is not yet supported
          So it's not the "follow-up" to 1.2.4.
            ahh fair enough. same results as above after a second flash by the way. this is a work in progress i guess. ill be on the lookout for wasser-1.2.4 update
              Nice one wasser!
              Gonna try this rom strait away.
              Thanks for your hard work!
                Tried this rom but some things are realy off with this one. Here's some feedback of my findings.
                -random reboots
                -sometimes switches from 1080p 24hz to 720p 60hz by itself.
                -get a striped screen sometimes
                -i got audio sync issues on 720p and 1080p videos after more than 5 min playback (on mx player)
                i went back to your 1.2.4 wasser rom.
                  Sounded like a bad flash......Could be corrupt download.....
                    Hello Wasser ... Are you Working on Android 4.4.2 for ut1 or stopped?
                    gesendet von meinem GT-N7105; CM11 (Temasek v37) Android 4.4.2
                      For lack of time i'm not sure if i can continue to support ut1 in the future.
                        NOOOOOOOOO
                          Originally posted by Scalle0479 View Post
                          NOOOOOOOOO
                          What he said... please reconsider!
                            Really a shame. to the boot kernel and the audio over Optical version ran great ...
                              For what it's worth I installed this on my UT1 last night. Had one freeze and reboot while restoring apps but apart from that everything I need seems to be working. I noticed that the CPU was maxed out at all times (according to android tuner app) so dialed back the minimum CPU frequency a bit and it did not crash.
                              I'm happy to keep testing and keep you up to date with my observations if it means you will continue to support this rom.
