Sent from my HTC One_M8 using Tapatalk
Ugoos UT1 - wasser firmware - KiKat Android 4.4.2
Originally posted by SLHQC View PostHi Wasser
My unit is still crashing with the new kernel.
Any ideas?
Should I try reinstalling the whole rom? Is there a crash report I can access?
i cannot fix If anyone cannot tell me how i can reproduce this problem
Originally posted by wasser View Postit'strange, i have this kernel and firmware running and tested 1080p video playback without any crash.
I wish I knew. It just crashes at random times. I'll try reinstalling the whole thing...
I note already that the ability to delete apps from the main screen is lost again. I am referring to the little x that is supposed to come up at the to centre of the screen when an icon is long-pressed. Similarly, long pressing on an app in the app drawer allows me to place the icon on the main screen but not delete the app or select the app info.
Also no longer have the option to change launchers on the settings screen or turn the Google search bar on or off.
Originally posted by holli73 View Posthello,
where did you get the kernel from?
@wasser - i use beyond xbmc 3.4 but my live tv - is not smooth at all with the new kernel (from your post before) - i have freezers on video and audio.
best regards
holli
I'm now working on new xbmc based gotham for my wasser firmware. It looks good and plays 1080p video perfect, spdif passthrough is also supported in wasser xbmc too
I will upload it very soon.
wasser
So I reinstalled the original firmware and have been running for a couple of hours without any crashes so far. This is with the first kernel. I'll see how it goes and hold off flashing the new kernel until it starts misbehaving (hopefully it won't!)
I've also installed apex launcher to get around the inability to delete icons/apps...
Originally posted by wasser View Postbeyond xbmc 3.4 doesn't work correctly on kikat firmware, it's the reason why it's not smooth.
wasser
Originally posted by cbch View PostI've tested some nearest gotham xbmc versions, it looked like there hardware acceleration does not work as high cpu usage and not smooth(just a less).
which firmware and which xbmc version have you tested?
the xbmc-13-beta2 works perfect on my 1.0.1 firmware for UT1
Originally posted by wasser View Postwhich firmware and which xbmc version have you tested?
Originally posted by cbch View Postsome nearest nightly and stable versions, 13.1 beta2, 13.0 beta or something else on 1.01 firmware. They played smoothly just several minutes with high cpu usage, then not smooth...
Originally posted by wasser View Posthave you played video from local or from network? maybe network problem on your route?
I tested again, it happened with high bitrate movie. The movie with low bitrate will play smoothly, but high cpu usage is going on.Last edited by cbch; 25 May 2014, 03:40.
Ready to throw it out the window...
Well...
I've tried reflashing with the original kernel and also updating the kernel.. Unit keeps rebooting at random times, even when idle.
Can someone point me to a stable rom (even if it is laggy) just so I can see if the unit is actually capable of operating for a long time without crashing?
Otherwise can someone tell me if there is a crash log or something that I can find to figure out why this is happening?
I' just about tearing my hair out now...
There are currently 1434 users online. 0 members and 1434 guests.
