Ugoos UT1 - wasser firmware - KiKat Android 4.4.2
    Originally posted by SLHQC View Post
    OK thanks - I did that. Seems to have worked...
    Is this the correct version of the new kernel?
    Kernel Version
    3.0.36+
    [email protected]omain #329
    Friday May 2 21:34:23 CEST 2014
    yes, it's the correct kernel. Please take time and test it and let me know if the random crash is gone.
    It's very important for me. I plan to release 1.0.3 soon.
    It would be great if anyone can test this kernel and give feedbacks! i
    thanks
      Hello there. I flashed this firmware on ITaSee IT808 which is identical as Ugoos UT1 as far as I know. My problem with external hard drives got worse. It connects and just after disconnects. I googled and added USB hub to connect , also changed Power Settings of Seagate drive but no way...Is there a solution to fix it??
        thanks
        OK cool. I probably won't be able to t test until tomorrow night but i will get back to you as soon as I have the chance.
          Anybody please?
            I couldn't comment as I know nothing about your device. This has been tailored for the UT1 and if your device is different, even slightly, then you can't expect the dev to support it. I haven't seen anyone else complain about this issue so there's something wrong somewhere....
            Sent from my HTC One_M8 using Tapatalk
              I don't think it is a software problem too, I just wanted to have a solution. I will try with an external powered USB hub
                That's a good start.
                  Apparently these units don't supply enough power to run a USB powered hard drive. I raised this a while ago. Search the forums.
                    Ok thanks for the answer
                      thanks
                      hello,
                      i can not try - because there is no change for me to do the steps - because the box reboots all the time as mentioned before - only 2 remote commands freeze and reboot...
                      maybe i can test 1.0.3 for you upfront?
                      best regards
                      holli
                        Originally posted by holli73 View Post
                        hello,
                        best regards
                        holli
                        hello,
                        i used the 1.37 tool and flushed only the new kernel and so far the box is not freezing and rebooting - i keep testing
                        best regards
                        holli
                          I am using the original kernel without any problems at all. Is the new kernel for 3188T chips? Mine's a 3188 and capable of running at higher speeds.
                          I have to say that this is perfect so far. I can't test Ethernet address sticking after boot yet. This is fantastic so far. Thanks Wasser
                            hello,
                            where did you get the kernel from?
                            @wasser - i use beyond xbmc 3.4 but my live tv - is not smooth at all with the new kernel (from your post before) - i have freezers on video and audio.
                            best regards
                            holli
                              Wasser posted it a couple of pages back. I was just letting him know that I didn't need to use it. All good as it is.....
                                Still crashing with new kernel
                                Hi Wasser
                                My unit is still crashing with the new kernel.
                                Any ideas?
                                Should I try reinstalling the whole rom? Is there a crash report I can access?
