Ugoos UT1 - wasser firmware - KiKat Android 4.4.2
@wasser
Have you tried these guys http://allminipc.com/forum/
They seem to be on the UGOOS website and already have a kitkat release
Hi First of all great firmware for what i have seen so far for my UT1.
Before this firmware i had allminipc installed and had the same problems. I'm only having some issues.
Issue 1: I have a good wifi connection 65Mbps and 3 stripes but not internet. Turned offe ethernet a i am not able to test it. Tried everything but still no luck ( such as changing router etc )
Isse 2: I downloaded CPUZ and saw the chipset was RK3066 1.61Ghz and was expecting RK3188.
Uploaded the image via Batchtool 1.8 with the restore button.
Can anyone help me in the right direction,is it T version of kernel problem and how can i change kernel?
Thanks in advance.
DustyLast edited by Dusty; 24 September 2014, 06:51.
Originally posted by detrimental_dude View PostThe firmware crashes repeatedly while playing 1080 movies.
Any updates or fixes?
Which img-file to flash?
Hi Forum, to start with all the best for the new year!
I refer to http://www.freaktab.com/showthread.p...l=1#post153347 and the method pablo11 explained how to flash new firmware on a Ugoos UT1. This firmware from Wasser is really good but sometimes my UT1 crashes and the description from pablo11 was very helpful for me. Now I want to try the newer 'Kitkat Firmeware by Wasser Version 1.0.1 as per message 1 from this thread.
At the time that I flashed the Jelly Bean Version I used the method as mentioned by pablo11, using the 5 mentioned files in the 'image' folder that was given totally in into the RKBatchTool 1.7:
boot.img
kernel.img
misc.img
recovery.img
system.img
The new Kitkat Firmware is only one (1) img-file, not five.
My questions:
- should I only rename the new Kitkat file in 'system.img' or in 'kernel.img' ?
- should I leave the other (older files) in place and flash the package of 5 files again with only this renamed new file?
- or should I only flash the new (renamed) Kitkat img file?
Many thanks for all suggestions.
Regards from the Netherlands
Originally posted by flhthemi View PostKeep in mind that if you decide to return to Jellybean there are procedures you must follow to go back to it or you might brick your unit.
If Kitkat is not working well I will return to the old firmware which is JB and think about your advise.
There are currently 1445 users online. 0 members and 1445 guests.
