Blacklist of locked Down Version´s of RK3188 CPU
Originally posted by Nicholaswc View Post
Originally posted by torbvea View PostHello!
You said that you were using HDMI passthrough for DD 5.1 / DTS with your MK908II and Finless 1.5a. Can you please tell me what settings you are using? Does it work with XBMC? I can't get the hdmi passthrough to work with either XBMC, MX player or the stock player..
Originally posted by darekmarta1975 View Postbecause you have to write it suitable kernel and you will act on the 1.6 GHz
if you wrote the works on 1.6 and not 1.8 that is, the works on 1.6
Originally posted by in1 View PostSo you mean that RK3188-T can run at 1.6Ghz without problems? Hmmm, my impression so far was that it is limited at 1.414Ghz, I'll continue researching then, thanks.
My problems are that I can't change it (because the shipment to China would be more expensive than the device), and I don't know which device to choose, because at now only the Minix X7 seems to be surely equipped with RK3188 chip (but it's not enough portable for my uses).
Originally posted by cluster_danneggiato View PostYes, I can confirm that my CX-919 works fine ONLY with Kernel at 1.4GhZ, not more, so simply it's not correct what is indicated by some vendors that declare RK3188 1.6GhZ.
Minix Neo X7
Originally posted by stubuchy View PostThat is great news for them as if true will surely create them as the premium brand!will be ordering more if this is true!!
Just got mine X7 with mail today, can and will confirm that my model has RK3188!
Very happy man here!
And my "old" MK802IV has been returned to seller.
Originally posted by Phycopat View PostJust got mine X7 with mail today, can and will confirm that my model has RK3188!
Originally posted by Molle View PostMINIX have confirmed they'll only use genuine RK3188s. So getting an X7 is a safe bet.
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by darrellr View Post.... and so far the only vendor to do so?
I asked geekbuying a partially refund as the item is not as advertised (MK 809 III). I said my device is RK3188T CPU and not a RK3188 and explain it can't run @ 1,6Ghz. I put a link to this forum (in particular post #16) in my Email. Here is the answer.
Thanks for your reply ,and sorry for revert delay.
I got what your mean and have confirmed with the factory, the CPU is really 1.6 , only the item run some powerful apps like games, the CUP will reach 1.6 under over locking .As usual if the apps are not powerful , it is 1.4,as we know if the item runs under overlocking . it is not good to the item, so the factory has adjusted it , hope you can understand what we say,.Sorry for my poor explain in the last email and can't be got understanding .
Hope it can been understanding .
Have a nice day.
Sincerely"
WTF?
MK809 III - Geekbuying december 2013
I bought my two MK809III's through a seller on Amazon, it was fulfilled by Amazon. First I wrote them regarding the poor WiFi performance. I told them I could improve performance by adding antenna's to them. The Amazon seller refunded me $23.00 to cover my cost.
When I discovered the max clock speed was 1.42 GHz, not the advertised 1.8 GHz, I wrote to Amazon again expressing my concern with regard to this misrepresentation. Their reply was that I could either return the two units for refund with them paying the shipping or if I was willing to keep them they would refund me 20% of the purchase price since they didn't perform as advertised. I chose to keep them and received another refund amounting to $38.62. In total I was refunded $61.62. I'm very pleased with the good service from Amazon.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
linux blinking - blinks on 3 monitors but works on plasma tv
I always tried to connect my blinking mk902 to my 3 fullhd lcd monitors and lcd tv.
Now I connected my blinking mk902 to my Panasonic 720p older plasma tv (tv is 720p but accepts 1080p signal) and picture was steady not blinking at all. So either can be improved source (stock rom) or target (monitor with more tolerant electronics).
Newer minipcs with non stock work or don't work. It depends on combination of minipc and monitor. Because stock roms in such a minipcs are ok, it means, that there must be some patch or change in inicialization to work correctly.Last edited by tobr; 24 January 2014, 08:13.
Originally posted by tltester View PostBob, take a look on the discussion at Minix's forums about their 007FW, they've introduced the screen flickering then, and after a long way of complaining and proving the problem's existence they've finally fixed it by reverting kernel-level HDMI timing changes they've merged from rockchip's crap updates before. The 007e they released with updated kernel didn't suffer from this anymore. May be you could ask them for updated kernel source to see what's gone wrong...
I wonder if this is tied to mali?
You guys with flicker might try changing this to a 1 and LCD rez to 160, etc!
Remember all my custom ROMs I turned overlay off and set for 240. There might be something there.
The only thing to do when a Vendor starts misselling its goods it to firstly promote that fact anywhere you can to further highlight issues and then to stop buying them.
Purchasing power will always work if enough use it.
It's Amlogic for me the next time I purchase anything.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostThe only thing to do when a Vendor starts misselling its goods it to firstly promote that fact anywhere you can to further highlight issues and then to stop buying them.
Unfortunately they shipping only FedEx.
There are currently 3783 users online. 0 members and 3783 guests.
