CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
    Originally posted by shaunmt View Post
    I'd guess that's hardware failure of some sort... hope it's the SD card and not the tablet... got another SD card to try?
    ShaunMT
    Possibly... I'll have to search the house xD
      It'll boot your custom stock and regular stock...
      It'll boot your custom stock and regular stock. Does this rule out it being a tablet problem?
        Probably... CWM mounts the partitions a bit differently.
        Try redownloading CWM, if you didn't already.
        Have you ever flashed a ROM on the tablet?
        ShaunMT
        Freaktab Rom Developer
          ShaunMT
          Already redownloaded the image, and I've tried flashing a ROM on the tablet, but it failed before doing anything.
            Re: CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
            That makes me wonder if it is failing to mount the internal nand partitions.
            Sent from my SPH-L710 using Tapatalk
              Originally posted by thebiggboss180 View Post
              IT DID A PERFECT BACKUP FILE in next800t---i will use the restore option when i need
              What confuses me, is why, exactly, is it working for thebiggboss but not me? It has to be some issue on my part, but I can't seem to find out what it is
                cwm
                same here fails on the signature varication
                  Can this be used on tablets that have been bricked?
                  I am assuming that I should wait for the unbrick kits.
                    What are you talking about? CWM, by default, doesn't even do signature verifications.
                    You're doing something very wrong.
                    ShaunMT
                      Probably not, read the thread, this has already been explained. If you're bricked (no screen display), you've got a bad bootloader, which means you've probably got the other board version and are going to need an unbrick kit, a different recovery version, and a new ROM version.
                      It won't be too long now...
                      ShaunMT
                        I was looking over your past posts, and It looks like you bricked your tablet by installing one of my prevoius ROMs and have been trying to fix it ever since? Is that correct?
                        I think you've got the the other board and will probably need an unbrick kit, a different recovery version, and a new ROM to get it working properly.
                        ShaunMT
                          ShaunMT
                          think i figured out what i did tring again in a sec my eyes arent good righr now put the file in wrong spot dumy me put it in a zip file with the rom by mistake goes to black screen after i try to get to recovery pull sd card out and can boot all way to hoome screen ? i have cwm now have to hold volume down key now instead of the up
                            That is the normal procedure.
                            Glad its working for you now.
                            ShaunMT
                              cwm
                              ShaunMT
                              do u know why i get erro on backing up my data the rest of nack up went good
                                Are you using a Next8HD8G with a NXM8000ND_WM board?
                                ShaunMT
