CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
    Re: CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
    I don't get any options work the wm build, but get them all in wmn. But wmn won't mount the system partition. Uploading pictures for reference.
    This is what I get from the wm recovery.
    This is what I get from the wmn recovery.
    This is the error I get from wmn when mounting /system for anything.
    Sent from my Event using Tapatalk
      So I had made a ROM for these a while ago (completely stock) and I just flashed it with CWM. It works (), but so far (I'm wiping data and cache and all that right now, hoping it'll fix it) the wifi will not turn on. Can anyone guide me through fixing this?
      Thanks,
      locuraconsigueusted
        Thanks,
        locuraconsigueusted
        Hopefully, wiping fixes it. I'm not yet aware of any WiFi issues on the WMN models, but I don't know anyone else who has flashed a WMN model without bricking it.
        Do you happen to know what your original ro.build.date was?
        ShaunMT
        Freaktab Rom Developer
          No, unfortunately. I know the serial is YFG1013, though
            I think I'm going to make a backup of my sisters' tabs and see if restoring then to move fixes it.
              I'll be posting ROMS based on the a stock build date of 10/28/13 for both Next8HD8G models very soon. The WMN version should be the correct one for yours (assuming they didn't change the WiFi chip during that month.)
              ShaunMT
                We ended up exchanging my wifes WMN (RED) for another one. After she installed all the stuff she wanted, I crossed my fingers and tried the CWM for her model. It worked!! I was able to make a backup of her tablet.
                Is there anything I might be able to get that would help you?
                  May I ask, hopefully without sounding like a total jack***, how soon is "very soon"? I've found it is more annoying having a working tablet without internet than a not working tablet.
                    Check your build.prop and let me know what the ro.build.date value is.
                    ShaunMT
                      Within a week.
                      If you're willing to test, I can probably get it to you in a day or three.
                      ShaunMT
                        I'm willing to test. Not like I'm using my tab for much else. :P
                          ShaunMT
                          Mon Oct 28 11:56:37 CST 2013
                            That is the newest version I have. I'll be releasing it soon.
                              So I fixed the Wi-Fi issue, but now it won't recognise my sdcard. It says that it is mounted, but going to settings > storage crashes the settings app and I can't save anything to it from the phone. Booting into CWM still works fine. Any ideas?
                                Mine does that sometimes. When mine does it, it seems to be because the cache is or dalvik cache is corrupted. Wiping cache and data usually fixes it for me. Sometimes the internal stock recovery seems to do a better job than the external recovery for some reason.
                                ShaunMT
