CWM Recovery with UBIFS Support For Amlogic Nextbook Tablets (Support Thread)
Originally posted by acidgirltogo View PostOnce in recovery how do I tell which ROM I need?
If I remember correctly, we determined that your tablet is bootlooping with an endless boot animation correct? Not stuck on a splash screen, not a lit up black screen or dark black screen, correct?
Remind me how it ended up in it's current condition. Was something flashed that led to this situation?
ShaunMTFreaktab Rom Developer
Originally posted by roadkill View Posti believe so i allways let my tablet do it had no probems
Not sure what else to try
Originally posted by pabeader View PostI tried using the tablet to do the erase and then used astro to unzip the cwm file to the card. still no joy. Doesn't matter how I combine the volume and power buttons, I only get the internal recovery program.
What are the values of the following entries in your build.prop file?
ro.product.model
ro.product.board
ro.build.date
Originally posted by shaunmt View PostAssuming you've installed CWM correctly on the external SD card, the only other reason I can think of that would prevent it from booting would be if you have some strange tablet version.
ro.product.model NX008HD8G
ro.product.board NXM8000ND_WM
ro.build.date Fri Apr 12 21:56:47 CST 2013
ShaunMT
Originally posted by pabeader View PostCan't really do the file wrong. There isn't an 'install' just extract to the root. Since I have no folders on the card, it must be the root.
It sounds like it's installed correctly, and I think it should work fine on that model version and build date.
Have you tried redownloading the recovery in case the file was corrupted during download?
I think you said you already tried reformatting your external SD card, correct?
Sorry about that, guys! Apparently, astro didn't extract the file just the file name. I just plugged it into my laptop and it had 0 bytes. redownloaded it just to be sure and extracted it to the card while on the laptop.
Did volume+ and power. Yeah!! success.
Glad you figured it out!
There are currently 2445 users online. 1 members and 2444 guests.
