I took the Nov '13 Geekbuying ROM and removed all the crap apps.
Installed Kit Kat Launcher.
If you have issues with cam use app in the zip to reset usb interface.
All the RK Stock Apps are in a folder.
To install run the flash tool...everyone should be familiar with this. Pick your parameter file. I built this from MK808 stock and I ripped the kernel out of the MK808B and included....this should work for both...
Added CWM install method. Cant adjust parameter this way.
After first boot....set time and date...fix scaling...and update all apps in play store....until you update all the apps the launcher looks funky and acts weird....after update everything becomes stable.
After install rename the cwm file and put on your sd card or flash only the cwm recovery image after it boots one time normally.If you do on the first flash the nand never gets formatted.
Some apps show as not compatible in the Play store....use market helper if necessary. Will work on this.
Please provide feedback.
This is my first rom....
13942 Antutu Score On Demand Deadline
ROM Flash Tool Install
https://drive.google.com/file/d/0B3TiLeRos6LpMVNCaFp0am9lbG8/edit?usp=sharing
CWM ZIP Install MK808
https://drive.google.com/file/d/0B3T...it?usp=sharing
CWM ZIP Install MK808B
CWM Libstagefright update
Stock Speeds Kernel except GPU full speed 100% for Buttery Smooth GUI
Sh!ts and Giggles Kernel Full Speed 100% CPU, GPU, and RAM WARNING NOT STABLE FOR ME
Skype That Works with this Rom
Removed Apps for those who used CWM
RKRemote Must install EHomeMediaCenter from Removed Apps Above
Perfect XBMC build
