Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
Originally posted by kubetts View PostYes, thanks. For playstore error 403?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Code:http://appslova.com/android-fix-app-could-not-be-downloaded-due-to-an-error-403/
- Go to system settings>> Accounts>>Google>>remove your Gmail account
- Now from settings>>Apps>>All> Force stop, Clear data and cache for Google Play Store, Google Service Framework and Download Manager (like in method 1)
- Now again go to settings>> Accounts>>Google>>Add your gmail account
- Restart your android and then accept all the Google terms and setup Google settings
- Rerun Google Play Store and update or install your app.
Ps. After a year of using mk808 it is more imported to me how system works is it stable play movies smoothly without choops. Than high antutu score.Last edited by xes; 12 February 2014, 09:38.
You are correct Antutu doesnt mean a thing to me but it does some...this is the first time i ran it.
In my humble opinion i think with the XMBC on the first post and the libstagefright updated this is my best build.
Up to this point I used digitopmod sep for a long time with xbmc gotham that i updated periodically. Movies played well but ui was terrible....Long boot times...flash wasnt that great....xbmc was flakey and i had to restart all the time. XAF worked well i just didnt like it
UI is very responsive. Web browsing is great....handles flash like a champ. XBMC is good from what i can tell but i dont have any super high bitrate moves....
Also it is 720 kernel with stock everything freq on cpu mem and ram...I would like to try the uhost u2 1080 kernel but havent yet.
Give it a try....use the cwm install and you dont have to use your computer. On that thought i will put all the rkapps....usbfix etc in a seperate file so you dont have to pull out a pc.....make a good backup and give it a whirl.
The purpose was to make a clean small install that anyone could make a base on to suite there needs.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by kubetts View PostGreat ROM. ThanksLast edited by prahjister; 12 February 2014, 21:20.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by mowgli View PostLove your ROM
What utility did you use for setting the SPU ?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by mowgli View PostSorry, it was a typo, I meant CPU.
So what tweaks ? I am asking because the score I got was around 11200.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1825 users online. 0 members and 1825 guests.
