Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
    Originally posted by nmitr11 View Post
    I flashed the version 1.0 for mk808b with cwm after wiping data all went well but after reboot i couldn't get passed the android screen. Any suggestions?
    Can the kernel with 100%gpu be flashed to stock jb 4.2.2?
    Did you do the wipe right after flashing.....is so do the wipe first then flash....there is a routine it does right after flashing that does something...hope this helps. Or you can flash the tried and true method the other way.
    The kernel will work with stock.
      Originally posted by hgfdsa View Post
      Any chance of getting this to work with Uhost 2 and have BT with wifi? There are different version of the wifi for Uhost 2 AFAIK.
      Anyways thanks for taking the time to make the rom.
      Flash with your stock kernel and boot and give it a try.
        Sorry guys i went through the motions on the latest stock rom that someone found and debloated everything....i got it allready and i noticed that there is no HDMI passthrough...and the processor only scales to 1.4....it is newer but i dont see an advantage over the other rom....the video drivers seem to be a little better when watching utube videos. Bluetooth is under settings on this one....If you are interested i can post just let me know...
        I would like to do an update....i can bake other things in just let me know....I know i want to include es file explorer....terminal emulator seems essential as well.
          imho must have stuff
          - DNS changer app (simple one that remembers custom/auto DNS)
          - Adaway
          - ES file manager
          - terminal emulator
          - ps3 and 360 controller support
          - pre SU rooted of course
          optional (maybe better to be left til install after)
          - mx player
          - beyond xbmc
          - archos video player + all codec
          I haven't tested your rom yet but definitely will once you get your v1.1 all ironed out. Looking forward to it.
            Re: Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
            If you have the time go ahead and post it. Always look forward to flashing and testing. Some baked in stuff would be awesome such as esfile explorer and such. Thanks for doing all of this!
              great room many thanks for this
              imho must have stuff:
              a 1080 kernel plz
              cya
                a 1080 kernel plz
                cya
                Uhost 2 1080 kernel works...boot logo looks bad but after that it looks good
                  I need a b version...i cant continue until i do....i have been able to flash and use the b version on my non b....anyone have one for sale?
                    mk808 here
                      erased
                        Init.d
                        delete
                          prahjister -
                          mo123 seems to have included a Netflix that gets hd in his rom (http://www.freaktab.com/showthread.p...re-Edition_Rom ) any chance you can provide too? rather not switch roms!
                          thx
                            Originally posted by slcpunk View Post
                            prahjister -
                            thx
                            Let me look into this....i did some initial testing last night....it may no longer be valid
                              I hope no one installed init.d....if you did you need it messes up the file system...reload backup or
                              run these commands in terminal emulator
                              su
                              mount -o rw,remount /system
                              Sorry i didnt catch this while testing
                                Another question (sorry!) I tried searching but typically forum search functions sort of ... blow...
                                Anyway, since I have a keyboard with touchpad, I keep activating the gestures "swipe from left" and "swipe from right" that open some strange search mode or the contact application. I can't stand it, and I can't find where the setting is. ( The gesture is if you start at the very edge of the touchpad and swipe into the pad, but with a small touchpad, this happens all the time by mistake just dragging around )
                                Anyone know how to turn those shortcuts off?
