Prahjister ROM 1.0 MK808(B) 2/8/14 4.2.2
I just re-flashed the ROM, installed the CWM. Rebooted into recovery mode and installed the new libstagefright library. Once I did that I cannot reboot to the ROM it remains on the "android" screen
I already tried to wipe all the caches but it didn't help.
What am I doing wrong?
I have an original mk808B and in the flash tool I selected parameter2gb file and MK808Bkernel.
I reflashed several times and can confirm that the culprit is the libstagefright.zip from the first page.
Originally posted by mowgli View PostI just re-flashed the ROM, installed the CWM. Rebooted into recovery mode and installed the new libstagefright library. Once I did that I cannot reboot to the ROM it remains on the "android" screen
I reflashed several times and can confirm that the culprit is the libstagefright.zip from the first page.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostTry redownloading and make sure not to open the zip file in windows...I haven't tested yet....just a thought......anyone else have trouble with libstagefright update? if you can download with the browswer on the mk808b straight to external sd. Something in windows might change the zip file...that libstagefright cwm should work on any rom....it is always in the same spot.
I'll try to do as you said later today.
Thank you!
Originally posted by mowgli View PostIt worked when I copied the ZIP into my internal SD card and installed from there.
Very strange.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by padonkadonk View PostI have installed MK808B yet I don't see Bluetooth being available. Is there a way to fix this?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostPrahjister 1.0
To install run the flash tool...everyone should be familiar with this. Pick your parameter file. I built this from MK808 stock and I ripped the kernel out of the MK808B and included....this should work for both...
Added CWM install method. Cant adjust parameter this way.
First, thanks for what looks like a promising ROM. I have a question about install. Can I use CWM and install over Fineless 1.7c? The only reason I ask is the comment you have about the "parameter file" and the fact that I swear I read somewhere about CWM not working for 4.2.2 ROMs ... of which I think yours is.
Originally posted by slcpunk View PostPrahjister,
First, thanks for what looks like a promising ROM. I have a question about install. Can I use CWM and install over Fineless 1.7c? The only reason I ask is the comment you have about the "parameter file" and the fact that I swear I read somewhere about CWM not working for 4.2.2 ROMs ... of which I think yours is.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by potes View PostPlease can you tell me if miracast it's working with these room? I'm trying to find a custom Rom that support well this service. Thanks in advancePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Sh1ts and giggles
I added some kernels that only have....
GPU at full speed all the time.
Ram at full speed all the time.
And CPU with lowest and highest settings available. 252 and 1.6
I did include an overclocked ram at full speed.
See first post.....
Thank you overclockomatic.
Also added more realistic kernel that is stock speeds but GPU is full speed all the time.Last edited by prahjister; 15 February 2014, 04:53.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1654 users online. 0 members and 1654 guests.
